Removing unwanted expoxy squeeze-out
Forum topic by Bret posted 1131 days ago 574 views 0 times favorited 4 replies Add to Favorites Watch
View Bret's profile
Bret
162 posts in 1662 days
1131 days ago
Topic tags/keywords: question
I’m planning to stop by Woodcraft this afternoon to ask their input as well, but here’s what happened:
I’m building a frame for my wife for a Mother’s Day present. It’s tiger maple with santos mahogany trim. The maple is already dyed & oiled; the mahogany is as yet unfinished. I’m planning to go with a wiping varnish over the whole thing.
Unfortunately, gluing the maple into the mahogany trim (I glued each up separately to ensure good corners) didn’t go so well. There were some gaps and I thought I’d just spread some epoxy in them to fill & bind—the gaps are all on the back side of the frame, so who’d ever see? I clamped the piece face-down on my workbench and did exactly that.
Woe was me a few hours later when I removed the clamps. The frame had stuck to the piece of hardboard I was using to protect the frame’s face, and I mean it was STUCK. Lots of epoxy had run down the mahogany and a slight bead had formed along one edge where the maple and mahogany meet.
I’ve been able to remove much of the larger spill by going at it first with a chisel and then following up with sandpaper (80 grit for now—I’ll clean it up with higher grits later) but was wondering if there’s a better way to remove the epoxy that’s up against the maple? I really don’t want to have to sand it all down and refinish it again but if I have to, I will.
Also, how far down do I need to sand? Until I can’t see any more darkness from where the epoxy soaked in a bit?
Thanks. Feeling rather stupid, especially since I remember thinking, “I wonder if any will spill through? No, that couldn’t happen….”
-- Woodworking is easy as 3.14159265358979323846264338327950288419716939937510...
View tblank's profile
tblank
49 posts in 1138 days
#1 posted 1128 days ago
I think you may have to take it down to bare wood to remove any trace. A friend uses thinned out epoxy as a finish and it is bullet proof. He has test pieces that have been in the weather for five years with no fade or breakdown. You can follow up with a rubbed wax over it to polish it up. Also I learned the hard way about 80 grit in a random orbit will leave tiny swirls that don’t show until stain is applied. Be sure to go as fine as it takes to circumvent this. Epoxy is VERY aggressive stuff.
87068 posts in 1745 days
#2 posted 1128 days ago
Sorry about that. It’s the sand of and refinish routine Epoxies a tough one.
View swied's profile
swied
74 posts in 1930 days
#3 posted 1127 days ago
Yeah. You need to sand it down to remove the epoxy. I was going to suggest that you epoxy the whole thing, but then I read that you already oiled the maple. Epoxy doesn’t get along with oil (fish-eye city).
-- Scott, San Diego
View Bret's profile
Bret
#4 posted 1127 days ago
I think what I’m going to do is run the whole thing over the tablesaw to remove the current edging and then mill new edging a bit differently to try to keep the proportions the same. I just don’t see a good way to remove the epoxy even through sanding since the edging sits higher than the main frame body.
Thanks for the ideas—I had figured this was going to be my only real option but figured I’d toss it to the group and see what other ideas might exist. Thanks again!
