drilling straight with hand drill (without jigs)
Forum topic by treesner posted 06-01-2016 05:44 PM 950 views 0 times favorited 13 replies Add to Favorites Watch
View treesner's profile
treesner
167 posts in 1111 days
06-01-2016 05:44 PM
Hey guys, wondering if theres any method to learning to drill straight with a hand power drill? I know you can use multiple combination squares or corner guides but i’d like to get good at it without relying on those. Is there any body technique that helps ensure a straight hole. For instance to saw straight with a hand saw making sure you’re square with the piece and your sawing arm freely moves in a straight line.
thanks,
-chris
13 replies so far
View Viking's profile
Viking
880 posts in 3342 days
#1 posted 06-01-2016 06:03 PM
I bought one of these, several years ago, for drilling items that won’t work on drill press. Works very well.
https://www.amazon.com/Wolfcraft-4525404-Attachment-4-Inch-8-Inch/dp/B000JCIMEA?ie=UTF8&*Version*=1&*entries*=0
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View Dan's profile
Dan
722 posts in 2039 days
#2 posted 06-01-2016 06:05 PM
Duct tape around your elbow, wrist, and wrist to drill. clamp work piece to lazy Susan on waist high small diameter table. Have an accomplice slowly turn the Lazy Susan. :) Do not turn on the drill.
-- Dan
View HokieKen's profile
HokieKen
6293 posts in 1285 days
#3 posted 06-01-2016 06:28 PM
Personally, I put my left hand on the butt of the drill, then get it lined up. Then, keep your left hand (or right if you’re lefty) right above the drill bit with some down pressure. You’ll be able to “sense” it if your hand sways off-axis. Hope that helps…
-- Kenny, SW VA, Go Hokies!!!
View jdmaher's profile
jdmaher
435 posts in 2726 days
#4 posted 06-01-2016 06:45 PM
There are several tricks that use mirrors (or mirror-like surfaces) that help you “see” if the bit is truly plumb. I used several – until I sorta got the “feel” of it, or at least good enough.
Try this one from Timber Frame Tools, which uses an old CD as a mirror-like surface to see “straight”.
-- Jim Maher, Illinois
View onoitsmatt's profile
onoitsmatt
395 posts in 1323 days
#5 posted 06-01-2016 07:07 PM
+1 on the CD trick above. Your drill may have a bubble level built into it. You could keep your eye on that, but this assumes the work piece is level as well.
-- Matt - Phoenix, AZ
View bondogaposis's profile
bondogaposis
4993 posts in 2498 days
#6 posted 06-01-2016 07:15 PM
You also drill a hole in a block of wood on the drill press then clamp that to your work piece and use that to get your hole started.
-- Bondo Gaposis
treesner
#7 posted 06-01-2016 07:24 PM
- onoitsmatt
i don’t have a bubble on the drill, is that something i could glue on? seems hard to get it initially level before glueing
treesner
#8 posted 06-01-2016 07:24 PM
- jdmaher
oh yeah thats interesting, kind of like the saw reflection trick.
View bandit571's profile
bandit571
21298 posts in 2830 days
#9 posted 06-01-2016 08:06 PM
Just place a square to sit where you can see it and the bit, maybe use two.
As for me…....
takes a bit of practice…
View Jim Finn's profile
Jim Finn
2682 posts in 3069 days
#10 posted 06-01-2016 08:09 PM
I learned how to do this because I spent 36+ years as a sheet metal worker and we run in screws with a drill motor and no pilot hole. Get some sheet metal screws and try driving them into some sheet metal. If you are not perfectly plumb as you start the drill the screw will go flying. Practice will get you there.
-- No PHD just a DD214 Website> craftingcouple.com
View MrRon's profile
MrRon
5086 posts in 3390 days
#11 posted 06-01-2016 10:05 PM
I find that drilling in a horizontal plane vs a vertical plane makes it easier to keep the drill perpendicular to the work. I brace my arms to my body while holding the drill with both hands. Sawing a straight line takes practice. I find here that a Japanese “pull” saw keeps my cut line straighter than with a “push” style saw. The less set on a Japanese style saw helps keep the blade from drifting to either side. Western style saws have much more set allowing it to drift from side-to-side more easily.
View rwe2156's profile
rwe2156
3092 posts in 1627 days
#12 posted 06-02-2016 12:16 PM
My take is abandon the idea. This would be one skill not worth the effort because you are drilling in all different directions, horizonal, vertical, etc. and would be impossible to perfect.
I use guide blocks like Bondo described all the time. They only take a minute to make.
A decent bench top drill press if relatively inexpensive and a necessity for any shop.
treesner
#13 posted 06-06-2016 03:41 PM
Personally, I put my left hand on the butt of the drill, then get it lined up. Then, keep your left hand (or right if you re lefty) right above the drill bit with some down pressure. You ll be able to “sense” it if your hand sways off-axis. Hope that helps…
- HokieKen
this does seem to work pretty well, but only if the piece is clamped you can afford to use two hands
