| Forum topic by niki | posted 346 days ago | 587 views | 2 times favorited | 39 replies | ![]() |
346 days ago |
Good day everybody…long time no see…(or long time no jig…) I had to cut 110 mm (4-5/16”) diameter circles to plug some holes. I used 6 mm (1/4”) bit and using the router lift, I lifted the bit till I heard the first “ZZZZeeeeeee” (you know what I mean) and turned the board one round…turned the lift 2 rounds and the board one round and so on… Regards |
346 days ago |
Niki, I am continually impressed by your ingenuity. You regularly devise ways of doing things and after I’ve seen them they seem so straightforward, and still something I wouldn’t think of. Count me as one of your fans. -- When you give someone a chance it may well be their last. |
346 days ago |
Very cool, Niki! I love all those improvised clamps too. You are the great improviser! -- Tom, Surfside Beach, SC - Romans 8:28 |
346 days ago |
Thank you so much Russel I’m planning now something with fixed pivot that I can move to any distance on the router table to get any circle diameter….up to some limit of course… Tom Regards |
346 days ago |
You’ve made so many neat jigs, you aught to write a book. -- Bruce from Central New York |
346 days ago |
Why don’t you just make a trammel ? Bob -- A mind, like a home, is furnished by its owner |
346 days ago |
Thank you so much Bruce Bob Usually, I’m using materials that cannot be used for any furniture and normally, they are left overs of Melamine and I have many of them…the one that you see on the pics was used before as a small working table… Regards |
346 days ago |
Nicki I am confused.
I see a screw in the part and it looks like it is screwed to the table top? -- A mind, like a home, is furnished by its owner |
346 days ago |
Hi Bob The workpiece is held to the Melamine board with a screw and boes not penetrate into the router table itself. You are correct that the Melamine board is thick (3/4”) but the reason that the bit did not reach all the way through the workpiece was my fault…I left the depth stop locked (from previous job)....I used long bit (2”) that could easily go all the way up but…well, we all have our mistakes…. I’m planning to use 8mm (5/16”) so I shall get extra 3/8” depth. I don’t have much of a need to cut circles but I think that with trammel I shall need also a backing board under the workpiece (held firmly to the workbench) and a carpet tape to hold the workpiece to the backer board…in my opinion, my set-up it much simpler but, it’s just me… Regards |
346 days ago |
Hi Nicki Secondly,from safety point of view the smaller diameter cutters have a tendency to work loose in most collets and even more so if they are extended bits as you have used. It appears the your router table is about 1/2” thick, the melamine sheet is 3/4’ thick and the circle material is 3/4” thick. That makes it about 2 full inches of extension of the bit outside the router collet. For my tastes and working technique that is not a safe set up. I mention this because we have a number of people here just learning about woodworking machines and I would hate to see them counciled into a disaster or worse a personal injury. I firmly believe that the trammel setup is a far safer approach than what you have shown us here. Regards -- A mind, like a home, is furnished by its owner |
346 days ago |
Hi Bob You are correct that 1/4” shank – 2” long is tough on the router and even dangerous because it can break at high loads and I would not suggest a beginner to use them but… All the “kuntz” (German – trick) is in the way that I use it…because the router lift is outside of the table area, as you can see, I’m lifting the bit by something like 1/16” increment at every round of the workpiece and it’s very easy on the router and the bit (I can hear when it’s tough on them) and, I don’t have to stop to re-adjust the bit height. I know that not many people are “excited” from this router lift (only a few people on other forums asked me for more detailed information) but this primitive, $1 router lift is a “gold” for me and serves me much better than a $200~$300 lift would do…even for mortising with 3/4” dia (20 mm) bit, it cuts very easy because of the small increments. My router table is 1¼” thick and is covered with 5/16” “floor panels” I have a few long bits (already 10 years) and they are reserved for jointing, doweling and sometimes mortising. By the way, before, I was cutting occasional circles of 24” dia on the table saw (pic below) Regards |
346 days ago |
Thank you Nicki Cheers Bob Here’s a two piece top tramelled and then shaped with a pattern the rest is just lathe work. -- A mind, like a home, is furnished by its owner |
346 days ago |
-- You can discover more about a person in an hour of play than in a year of conversation. (Plato) |
346 days ago |
Wow Bob Well, of course everybody has a little bit different methods because we are not “Windows XP” that will work the same way all over the world… Even in a small group of people you can see the differences because everybody has a little bit different opinion, abilities, capabilities and skills and I think that everybody is correct in his way…. Do you remember the Grrriper post. I would not touch it but, many others (I think that everybody except me) where singing “Hallelujah” to this “Safety device” (not legal in EU)...on the other hand, I will not work on the Table saw without riving knife and guard while many people even does not remember where they put it (still packed it the plastic bag)...everybody is correct with his way…as long as no accidents… Tom (mot) Best regards |
345 days ago |
Nicki: Just for the record , I wonder if you could point me to the European regulation that bans the Grr-ripper. I see it advertised over there so now I am a bit confused with your information below: Do you remember the Grrriper post. I would not touch it but, many others (I think that everybody except me) where singing “Hallelujah” to this “Safety device” (not legal in EU) http://www.capellemanmachines.be/grr_ripper_veiligheids_duwstuk.htm Cheers Bob -- A mind, like a home, is furnished by its owner |
344 days ago |
Hi Bob Oh yes, they sell it also in UK…it’s a free country (or countries) and you can buy everything here (btw, in UK they advertise it as a “router table push block” but, everybody knows the real purpose) Of course you cannot control amateurs (like in USA) but for registered business the regulation states “Blade guard MUST be installed for ANY operation on the table saw” (as I remember the same OSHA regulation applies in USA) and if an inspector will come and find that somebody is operating the table saw without a guard…or in case of an accident, the guard was not installed…this guy will be in deep….trouble. Please have a look at this site (it’s a 260kb PDF file) and you will see a few interesting things about the EU safety regulations that because of them also the amateurs are getting better and safer machines. Regards |
344 days ago |
344 days ago |
Hey Nicki: The picture you directed me to shows the operators body position right behind the part being cut. I did not think that the UK rules would apply to the EU? I still can’t see where they (the EU) “banned” the Grr-ripper. BTW, aren’t most cabinet shops moving out or the EU due to high wages and costly unworkable regulations? Can you show me where that regulation is? Regards -- A mind, like a home, is furnished by its owner |
344 days ago |
I think the issue is that the Grrripper only works with the table saw when the blade guard is off the table saw. This makes it incompatable with OSHA requirements, and I think Niki is saying it also violates the EU’s (and probably the UK’s) labor safety requirements. -- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com |
344 days ago |
Peter. I was and am still asking to show me where the device is specifically banned. That has been the context of more than a couple of messages and I have not been able to isolate the remark. For some unknown reason, it has again, surfaced here- from an enirely different thread. It is quite possible that your observations are correct. I just wanted to stay with the facts. I have no vested interest in the Grr-ripper. Apart from that I just want to see that the truth is presented rather than an emotional opinion. Best Regards Bob -- A mind, like a home, is furnished by its owner |
344 days ago |
tom pass the popcorn please lol |
344 days ago |
Peter, only one of the many uses of the GRRipper involve having the guard off the saw…that is only when ripping very thin stock. For many applications using the tablesaw, the GRRipper is just an expensive and complicated push block. However, I own one and also, with no vested interest, have evaluated it’s value to me. I’m wondering about Bob’s concerns as well. -- You can discover more about a person in an hour of play than in a year of conversation. (Plato) |
344 days ago |
Hi Bob The EU safety regulations are one and they are the same for all the EU countries including UK and Belgium (the site that you pointed is from Belgium). They are translated to 22 languages of the EU countries. The Gripper is not “banned” in EU because it’s not dangerous as a tool…it cannot cause any injury by itself… unless, you through it on somebody :-) the “ban” is on using any device that requires the removal of the guard on any machine. Please go to this site and you will see many Q&A of the EU safety comity – Brussels – Belgium (as you can see on page 3) Also, please have a look on pages 115 , 116 It was just convenient for me to give you the UK safety regulations (the most easy to find) but they are the same regulations as in all the EU (that is very difficult to find). About the picture…it’s just a drawing but, we are not afraid to stand behind the part because we have Riving Knife and “Short fence” (by law) for ripping and that combination is satisfactory to prevent kickback….the new table saws in USA are equipped with riving knife but still operated with “long fence” that can cause a kickback and maybe that’s the reason that American table saws are equipped also with “anti kickback pawls” that are not required in EU. About the Griper, if you are visiting WoodNet you could read a few days ago that the handle just broke during operation and the guy had some thoughts about using it…very long post with many “anti” using the Gripper… By the way, here is what the US OSHA is saing about the guard So, there is no “ban” on the Gripper but if you’ll use it, you are not obeying even the US OSHA safety regulation. Regards |
344 days ago |
Niki, did that gentleman on Woodnet ever identify how he broke the handle on the Grripper? Having looked over the handle and construction of the unit, it escapes me on how one could possible achieve that. -- You can discover more about a person in an hour of play than in a year of conversation. (Plato) |
344 days ago |
Niki: The “regulation” you tossed up for the EU from the UK. contains a disclosure that saying that the information is only a guidline. Apparently you did not take the time to read it before offering it as a defense for your argument. I don’t know why you can’t just be satisfied with not using the gripper and or recommending it. If you don’t wish to use it then don’t. That’s a free choice. Saying that the use of this device is “not legal” in the EU is stretching the truth quite a bit too in that the EU has no jurisdiction in the “garage/hobby shops” of Europe just as the OSHA has none in the U.S. As for breaking the handle on the Gripper, I would like Tom, like to see how that was possible. If you look at the pic of the gripper above you will see that it will still function as it should even with the handle missing. You would have to roll over mine with a truck to damage it. Just to bring this discussion full circle back to the “jig” that you posted originally.
May I point out: You were the one that brought up the Gripper again. Cheers Bob -- A mind, like a home, is furnished by its owner |
344 days ago |
Bob – OSHA in the US does apply to individuals in certain cases … sort of. Me, for instance. I have been informed by the state that I am subject to OSHA requirements because I have a Federal Tax ID#. I am a sole proprietor with no LLC, no incorporation, and no employees, working out of my own shop on my property, but because I am doing business I am required to follow OSHA guidelines in my shop. I have no idea how that really contributes to the conversation, but I thought I’d throw it in there! -- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com |
344 days ago |
Okay, I don’t have a vested interest in the Grrripper, I don’t own one, so I haven’t evaluated it’s value to me. I can’t even remember how to spell it most of the time! My only opinion of the Grrripper is that it looks like a complicated push block, which seems to be substantiated by Tom(mot)’s comment. Anyway, I’m not trying to make a negative comment about the Grrripper because I have no experience with it – I’m just trying to see the truth presented, as Bob suggested. I took a look at the EU document that Niki pointed us to. Sheesh – the legal-ese is as thick in the EU as it is here. I didn’t read the whole document (I don’t have time to read all the regulations I’m supposed to follow, much less those for another country!). It appears from the language I managed to wade through that the “Recommendation For Use” is not a recommendation for how to use a piece of machinery, but a recommendation for the application of “The Directive” which seems to be the EU’s equivalent of our OSHA guidelines. If I’m reading correctly, the info on page 113 which Niki mentioned is a recommendation for application of the requirement in “The Directive” which apparently says that guards must be in place on manually loaded/unloaded machines. It is entirely possible that I’m misreading/misinterpreting this document and the “recommendation for use” does actually refer to use of the tool. If that is the case, it’s interesting to note that OSHA has “guidelines” which, along with “recommendations,” seems to indicate options or suggestions. However, OSHA’s “guidelines” are far from optional, so it is possible that the EU’s “recommendations” are also more requirements than suggestions. -- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com |
344 days ago |
344 days ago |
Hi Bob As I said on one of the above replies “of course you cannot control amateurs….”, if you call them “individuals”... I’ll not argue with you as English is not my native language. Woodworking, is not “Licensed” profession like Pilot, Doctor, Lawyer etc….anybody can practice woodworking without studying or passing exams while even an “amateur” pilot must have license and comply with all the aviation laws and regulations to practice his “hobby”. I’m sorry that I cannot present the actual regulations that clearly states that the blade guard must be installed for any operation because, those regulations are not published on the internet but you have to buy them as you can see here And I don’t think that they are just “Guide lines”...do you think that companies like Metabo (my table saw) and others would invest time and money to develop and install riving knife or enclose all the under side of the blade to comply with the “dust control regulation” or to make the blade to become to full stop within 10 seconds….and by that increase the price to $2000 and sell less machines…if it was only “guide lines”, they could make the same table saw for half price or less and have the same profit. Even the US OSHA is stating clearly that About my “jig”...I believe that this jig is unacceptable by the regulation but amateurs can do whatever they want… I think, that people are not “Windows XP” that will operate the same way all over the world What looks unsafe to one, looks very safe to the other…. Everybody has a little bit different way of thinking, abilities and capabilities and one way of operation that is good for one, is not good for the other… If one does not feel safe with the gripper, I don’t think that somebody should try to convince him that “that’s the correct and safe way for you” to work on the table saw…or, if it is, maybe OSHA have to make it a law (or regulation) and force everybody to use this “safety device” I’m just showing my jig but I never said that that’s the correct or safe way…I know that some people will not feel safe to work that way (...but will feel very safe to work without splitter and blade guard that, in my opinion, can cause much “better” injury…) and some people will feel safe to work that way (when I posted it on other forum, I was surprised by a guy that said that he is using this method for years…with pictures attached…). I was searching for the post about the Grriper handle that broke (and about the small plastic splitter) but mysteriously both posts disappeared….I posted a question about the posts and got a PM from the moderator that “We zapped it because it had turned into a personal sniping match..” sorry… Best regards |
344 days ago |
O.K. Nicki: So lets summarize: For what it’s worth Nicki, the reference you quoted above here pertains to hand held circular saws and not tablesaws. It would be a lot clearer for everybody if we just stuck with one tool at a time. I would like to take this opportunity to say, for the record, that I am in no way endorsing the use of any tool in the work shop or workplace. I am concerned only that the information provided here on this forum is as clear and concise as possible and does not mislead the people that come here seeking advice on this craft. We should all be aware of the fact the quotations should be properly referenced just as credits for the use of previously developed techniques should be acknowledged rather that claiming them as our own. It’s the right thing to do. Cheers Bob -- A mind, like a home, is furnished by its owner |
344 days ago |
Peter, It is quite possible that the Drones of Government have included you in their net simply because you have obtained that FED ID #. It might suggest that you could or would hire people to perform tasks for you in your shop. p.s. We don’t lose our rights all at once, they are taken away one day at a time. Cheers -- A mind, like a home, is furnished by its owner |
344 days ago |
I’m confused, so just to clarify your point, Bob – are you saying that a “hand fed rip saw” with a hood “above the table and … above the material being cut” (Niki’s quote) is the same thing as a “hand held circular saw” (Bob’s quote)? Or were you referring to a different quote from Niki? Other than the Festool, is there any hand held circular saw with a hood that fully encloses the blade above the material being cut? Rights? Anymore, they are more like privelages granted by the government. -- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com |
344 days ago |
Peter, as far as I can decipher Nicki has confused part of the regulations with those pertianing to a circular saw. Here’s what I am referring to: Quoting Nicki… above ””“Even the US OSHA is stating clearly that This has nothing to do with table saws and or the grr-ripper which he tried to congugate within his reply. Cheers Bob -- A mind, like a home, is furnished by its owner |
344 days ago |
Bob, you indicated you wanted to see the truth presented, so I’m trying to make sure we are calling an ace an ace and a spade a spade. I think you are interpreting “hand-fed” to mean the same as “hand-held”, which is an incorrect interpretation. You requested references be used so I have included links to the documents I mention. The quote “Each circular hand-fed ripsaw shall be guarded by a hood which shall completely enclose that portion of the saw above the table and that portion of the saw above the material being cut” in the OSHA guidelines (1910.213(c)(1)) must refer to table saws, and here’s why: Apparently OSHA doesn’t feel the need to use industry standard terms in referring to various tools, but I think by reading a paragraph or two it usually becomes clear what tool they are talking about. Hey, Tom(mot) – have you run out of popcorn yet!? -- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com |
344 days ago |
Hi Bob Lets start with the so-called “guide lines”..as I understand your interpretation to “guide lines” is; If I want – I use it…If I don’t want – I don’t use it… This web site is the official OSHA website On one side you are telling me that: But from the other side you are telling to the people that are “just learning about woodworking” that it’s ok to remove the guard and work with the Gripper….... I don’t know but, do you think that they teach the students in schools to remove the guard and use the gripper… If you will go through my posts you will see only one that my blade guard is removed…when I work with miter cutting sled…otherwise, on all my pictures you will see the riving knife and blade guard installed…not only to teach the beginners the safe way but also because I really use them all the time. Just for the record , I wonder if you could point me to the American regulation that bans my jig or method….. Cheers |
344 days ago |
343 days ago |
Instead of talking Gripper, we should be trying to find a micrometer to measure how fine a hair can be split. Now, how about a resounding chorus of “Peace on Earth, Good Will Toward All Men” Tom, got any popcorn left? -- Better to say nothing and be thought the fool... then to speak and erase all doubt. |
343 days ago |
Hey, Chip, I have a thin strip ripping jig that will split that hair way down! Just bring over the micrometer and the hair (you appear to have a better supply of hair than I do), and we’ll see how thin we can go!! I think Tom must have burned through a year’s supply of popcorn watching this discussion! Everyone now … “The wrong shall fail, the right prevail, with peace on Earth good will to men!” Er, I hope we aren’t offending anyone by our reference to a particular religious holiday. -- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com |
343 days ago |
Lordy Peter, is that really the whole sentence for “Peace on Earth?” Boy did I pick the wrong song. I gotta do better research from now on ;-) -- Better to say nothing and be thought the fool... then to speak and erase all doubt. |
341 days ago |
hey Chip.. I just saw that you changed your signature!!! I’m feeling better. Maybe Santa will bring me a present after all! -- "Functional WoodArt" by Debbie, Canada (http://www.execulink.com/~yohan) |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1337 |
| Become a sponsor |
1778 |
| Become a sponsor |
123 |
| Become a sponsor |
371 |
| Become a sponsor |
108 |
| Become a sponsor |
Woodworking Trade & Swap
251 |
| Become a sponsor |
Coffee Lounge
1004 |
| Become a sponsor |
LumberJocks.com Site Feedback
284 |
