In thicknessing a couple of large claro walnut slabs I discovered that the sap wood in the slabs in peppered with what I assume to be powder post beetle burrows. Whatever they are, they range from a tiny hole every few feet to sections of the surface that are a maze of burrows. I'd like to fill these with epoxy (system 3 with medium-speed hardener) but am concerned about getting the epoxy on the surrounding wood.
My final finish will be sam maloof poly/oil. My worry is that the areas that have epoxy overflow on them will look different than the areas that did not, because if the porosity of the wood. Would it be a good idea to apply a very light coat of the poly/oil before filling the holes with epoxy? If I didn't, how much sanding would i be looking at to clean the overflow areas of any sign of the epoxy having been there?
Also, any suggestions on adding pigment or wood powder to the epoxy? I don't mind their appearance one way or the other.
Smallest holes (for reference, the hole is 1mm in diameter):
Most concentrated areas of burrowing (these burrows are about 1mm wide each):
Front and back of both slabs:
Slab 1 top:
Slab 1 bottom (note sticker shadows):
Slab 2 top:
Slab 2 bottom:
Having never done this before, I'm open to any advice and intend to practice on scraps before pulling the trigger on any specific approach.
Thanks in advance.
Slab 1 top:
Slab 2 top:
Slab 2 bottom:
Thanks in advance.
