Attention Box Makers.....Please help!
Forum topic by Mark Blomster posted 04-14-2010 05:23 AM 1354 views 0 times favorited 6 replies Add to Favorites Watch
View Mark Blomster's profile
Mark Blomster
107 posts in 2949 days
04-14-2010 05:23 AM
Topic tags/keywords: hinges boxes
Hopefully I’m posting this in the correct area. I am a newbie.
Looking for advice on a jewelry box that I am making. I spent big bucks and bought the “Brusso” hinges! I routed the mortises and attached the hinges. The lid will not close unless it’s pressed down, and springs up 1/4” when not forced down.
My mortises are just a hair (maybe a 1/64”) deep, on all 4 mortises. Would this be the cause of the problem???
Any ideas? I appreciate any help that is offered. Thanks!!!! Lou
View bigike's profile
bigike
4050 posts in 3252 days
#1 posted 04-14-2010 05:47 AM
you might want to take the hinges off and see if the mortices are deep enough? after you take them off put the top on the box then see if the hinges slide into the mortices in the closed position.
Mark Blomster
#2 posted 04-14-2010 05:58 AM
Thanks Ike. The hinges slide into the mortises fine. There is even a little “slop” which I’m wondering if I should get rid of by sanding the lid and box with some 180 or 220 grit taped to a flat surface…
Let me clarify my original post. The mortises are about 1/64” too deep, so the hinge is sitting down just a hair.
View bladeburner's profile
bladeburner
88 posts in 3051 days
#3 posted 04-14-2010 05:09 PM
Sounds like the screws are pulling the back end of the top down and prying the front edge up.
View Albert's profile
Albert
508 posts in 3553 days
#4 posted 04-14-2010 05:22 PM
bladeburner has it right, you can try to put a little paper under the hinges as shims to raise them up a bit.
View CharlesNeil's profile
CharlesNeil
2385 posts in 3834 days
#5 posted 04-14-2010 05:35 PM
Paul has it right, shim the hinges higher, a small gap in the back doesnt hurt and insures the box wont bind up ,thats whats happening.
Mark Blomster
#6 posted 04-15-2010 05:31 AM
Thank you for your help! A business card shim worked perfectly and the box looks great!!! Thanks again.
