Need Drawer Slide / Glide Advice
Forum topic by davidroberts posted 04-14-2010 04:42 AM 1873 views 0 times favorited 10 replies Add to Favorites Watch
View davidroberts's profile
davidroberts
1027 posts in 3356 days
04-14-2010 04:42 AM
Topic tags/keywords: drawer glide slide
I’m building roughly 24” by 24” drawers and want to use drawer slides, or glides, whatever you may call them. I’ve built wooden slides, dovetail slides, etc, but on this project I want to try metal slides. Problem is, I’m way confused with all the choices. Is there a company out there that doesn’t make a line of metal slides? About the time I’ve decided on a specific brand or style, I find out I need another part, or I change my mind because I don’t know what I’m really buying. Price is a concideration. I don’t want to experiment or buy more slide than I need. I keep hearing about a “Blum-type”. What type exactly is a Blum type. Also what is easier, better, a side mounted or face frame mount. At this point in the project I can go either way.
I’d like some recommendations on a 22” full extension 75 to 100 pound slide that is relatively easy to install and won’t break the bank. I need 8 pairs. Thanks in advance.
-- Better woodworking through old hand tools.
10 replies so far
View Michael Murphy's profile
Michael Murphy
453 posts in 2875 days
#1 posted 04-14-2010 05:54 AM
Usually, you decide the slide you want to use, then make the drawer to fit it in the opening using the specified clearances. Some are side mounts that require a certain clearance, like 1/2”, others mount differently, but you need to know the slides before you make the drawers.
For full extension slides I always liked Accuride side mounts. That was many years ago and there are probably lots of alternative choices. Commit to the hardware and make the drawers to fit.
-- Michael Murphy, Woodland, CA.
dennis mitchell
3994 posts in 4185 days
#2 posted 04-14-2010 06:12 AM
Blum is a brand not a style of slide. Face frame mount or slide mount is just how it attaches. Design your project and buy the one to match. Blum, Accuride, KV are good brands. 75 lbs slides ballbearing slides will do the job. I like the cheap epoxy non ballbearing slides for economy they will last years.
View jack1's profile
jack1
2094 posts in 3898 days
#3 posted 04-14-2010 06:17 AM
Rockler is ok. Go to Home Depot and check their stuff. I’ve used it and it’s ok too. Some of the better wood suppliers also have some like Hughe’s Hardwoods in Stockton, CA. for an example.
View lumberdustjohn's profile
lumberdustjohn
1263 posts in 3037 days
#4 posted 04-14-2010 02:10 PM
To many to choose from.
Self closures,
Push to open,
Prices vary from 6 bucks a pair to 20+.
Local hardware, Lowes or Home Depot is double the price.
I purchase from Hershberger Hardware in Baltic Ohio.
Lots of other places to buy.
Deside if you want them to be hidden or not.
I use side mount.
Why a full extension 22” on a 24 ” drawer?
-- Safety first because someone needs you.
View pvwoodcrafts's profile
pvwoodcrafts
239 posts in 3792 days
#5 posted 04-14-2010 02:14 PM
I use KV’s from woodworkers hardware. 8400 series I think, #100 full extension , and I always use their metal bracket to attach to the back of the cabinet.
-- mike & judy western md. www. pvwoodcrafts.com pvwccf1@verizon.net
View davidpettinger's profile
davidpettinger
661 posts in 3071 days
#6 posted 04-14-2010 05:38 PM
Dave, here is the place I use. I think they are great. You name it, they got it.
http://www.drawerslides.com/c/100-lb-drawer-slides
-- Methods are many,Principles are few.Methods change often,Principles never do.
View PhineasWhipsnake's profile
PhineasWhipsnake
77 posts in 2918 days
#7 posted 04-15-2010 03:52 AM
I’ve built dozens of drawers, and I wait ‘till Woodpeckers has their (at least) annual drawer slide sale. I get 22” full extension 100 lb capacity ball-bearing slides for less than $10 a pair, but you have to buy 10 pair at a time.
-- Gene T
View John Gray's profile
John Gray
2370 posts in 3756 days
#8 posted 04-15-2010 04:48 AM
I agree with 3fingerpat above but I prefer zinc finish instead of black.
http://www.rockler.com/product.cfm?page=21473
I’ve used these slides on several projects they work fine and I’ve had no problems with them.
View JerrySats's profile
JerrySats
237 posts in 3480 days
#9 posted 04-15-2010 05:15 AM
View iamwelty's profile
iamwelty
257 posts in 2986 days
#10 posted 04-15-2010 02:51 PM
I’ve never had a problem with Blum sliders
-- There is a fine line between eroticism and nausea...
