grinder paddle switch vs normal switch
Forum topic by treesner posted 05-31-2016 12:58 AM 1527 views 0 times favorited 6 replies Add to Favorites Watch
View treesner's profile
treesner
167 posts in 1167 days
05-31-2016 12:58 AM
curious of the benefits and draw backs of the paddle switch on an angle grinder are?
I was considering this miluakee one and see it comes in different options. I plan to use it with a sanding disk for wood carving stool seats and such
http://www.amazon.com/Milwaukee-6146-30-2-Inch-Grinder-Paddle/dp/B0052UWYE8?ie=UTF8&ref_=cm_cd_al_qh_dp_i
Also if you have an opinion on 4.5 vs 5 that would be helpful
View Loren's profile
10477 posts in 3850 days
#1 posted 05-31-2016 01:23 AM
For sanding I would want to be able to lock it on,
but for using a carving head I dunno. Safety
issue mostly.
runswithscissors
2892 posts in 2228 days
#2 posted 05-31-2016 03:41 AM
I have always preferred the paddle switch. My first one (which still runs like a champ after new brushes a couple of years ago) is a B & D about 40 years old (I bought it new). Unlike current paddle switches, it doesn’t have the little device you have to flip to turn it on. That’s a safety device to prevent accidentally having it come on when you set it down. I am always conscious of that danger, and have never had a problem.
What I like most is probably the fact that it’s off instantly as soon as you let off on the paddle. It does have a lock-on button, but I have rarely needed it.
I use mine on an almost daily basis, not only for metal, but with the right discs, for shaping wood as well. HF has a dish shaped carbide disk for rough shaping, and flap sanders (with overlapping sanding flaps) are available in both flat and dish (convex) configurations.
They are a powerful and versatile tool.
5177 posts in 2696 days
#3 posted 05-31-2016 10:54 AM
I also prefer the paddle switch, but I’ve not carved wood with one.
treesner
#4 posted 05-31-2016 04:17 PM
do any of the paddle switches have a variable speed like how air guns work (i’ve only seen variable speed as a separate dial)
View mpounders's profile
mpounders
902 posts in 3098 days
#5 posted 05-31-2016 04:26 PM
Paddle switches are just easier to turn on and off, rather than searching for the other type. For carving especially, it gives better control and safety. especially if using a chainsaw type disc. I have both types, but favorite is the paddle.
-- Mike P., Arkansas, http://mikepounders.weebly.com
runswithscissors
#6 posted 05-31-2016 07:30 PM
I’ve never seen one with a variable speed. Since they are a universal motor, you could use a router speed controller, but the switch would still be just on/off.
