veneer laminating problem
Forum topic by liong43 posted 04-14-2010 01:52 AM 1050 views 0 times favorited 2 replies Add to Favorites Watch
View liong43's profile
liong43
1 post in 2838 days
04-14-2010 01:52 AM
Topic tags/keywords: veneering
I have many times got problem when laminating basswood veneer on mdf / particle board. the veneer delaminated an seem like bubble on the surface. I used hot press to do this job, But when I laminate other veneer like oak and cherry, it almost perfect. Please help me to find the solution. I am looking forward your help. Thanks.
Best regards,
Liong
2 replies so far
View Peter Oxley's profile
Peter Oxley
1426 posts in 3746 days
#1 posted 04-14-2010 02:17 AM
I’ve never tried to laminate basswood, and I’ve never used a hot press, so these are guesses.
Basswood is not very dense at all, so I have a feeling it would expand and contract a lot with changes in temperature and humidity – probably much more than oak or cherry. The heat from your process may be causing the wood to change size, causing delamination problems. I don’t know if your glue is a water base, but if it is that could add to the problem.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View davidpettinger's profile
davidpettinger
661 posts in 3072 days
#2 posted 04-14-2010 04:06 PM
Veneers can be tricky, especially if you are not using the right method. My suggestion is to give these people a call and see if they can give you some answers. http://www.oakwoodveneer.com/index.html
-- Methods are many,Principles are few.Methods change often,Principles never do.
