Need some advice.
« back to LumberJocks.com Site Feedback forum
Forum topic by Eagle1 posted 04-13-2010 10:31 PM 1085 views 0 times favorited 8 replies Add to Favorites Watch
View Eagle1's profile
Eagle1
2066 posts in 3058 days
04-13-2010 10:31 PM
Topic tags/keywords: question
I just purchased some rough sawn walnut some of the bark is still on the edges. I’m wanting to make a couple of projects, but I want to leave the bark on some of the project. My question is how do I make it so the bark will stay attached to it..
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
8 replies so far
View richgreer's profile
richgreer
4541 posts in 3068 days
#1 posted 04-13-2010 10:38 PM
give it a good dose of CA glue (thin).
Eagle1
#2 posted 04-13-2010 11:51 PM
I just looked at some of the boards. The bark seems good and tight. I’m wanting to make a couple of jewerly boxes, I want to leave the bark on the front of the bottom (base) of the boxes. Is there a coating or something that will help if from coming apart and keep it on the board.
View interpim's profile
interpim
1170 posts in 3452 days
#3 posted 04-14-2010 01:30 AM
rich isn’t steering you wrong.
flow some thin CA all through it. It will essentially plasticize the wood where it gets in.
-- San Diego, CA
TopamaxSurvivor
18265 posts in 3669 days
#4 posted 04-14-2010 02:09 AM
If it was cut in the spring or summer it is more stable than winter cut.
View Michael Murphy's profile
Michael Murphy
453 posts in 2998 days
#5 posted 04-14-2010 02:55 AM
Pull it off and then glue the whole thing back on.
-- Michael Murphy, Woodland, CA.
Eagle1
#6 posted 04-14-2010 01:27 PM
I never dought Rich. I misunderstood what he was saying, I was tired. Some days that happens to me because of my seizure disorder.
View Dusty56's profile
Dusty56
11819 posts in 3681 days
#7 posted 04-17-2010 12:00 AM
Topamax , I’ve been told that if you want the bark to stay on , it should be cut in the Winter because all of the excess moisture from the growing , moving outer layers is gone and the bark is therefore tighter to the tree, naturally making it more stable. It’s like green wood versus kiln dried .They used to cut trees in the Spring if they wanted to remove the bark because with all of the high moisture content , the bark would pretty much pull right off of the wood once they made a split in it to get it started.
TopamaxSurvivor
#8 posted 04-17-2010 04:30 AM
I probably got it backwards, I hate these senior moments ;-))
