Sharpening a #8 plane iron
« back to Hand Tools forum
Forum topic by mandatory66 posted 05-30-2016 02:19 AM 825 views 0 times favorited 8 replies Add to Favorites Watch
View mandatory66's profile
mandatory66
202 posts in 2186 days
05-30-2016 02:19 AM
I am thinking about buying a #8 plane but am having some questions about how to sharpen a 2 5/8 inch plane iron. I use a jig for sharpening and am not good with a freehand style. The stones I have are only 2 1/2 inches wide and I am not sure a 2 5/8 inch iron will fit in my Veritas jig. Wondering how everyone sharpens these wide irons,other than free hand.
8 replies so far
View TheFridge's profile (online now)
TheFridge
9714 posts in 1541 days
#1 posted 05-30-2016 02:30 AM
Make your own i would say if it doesn’t fit in your guide.
The edges need to be relieved anyway or you will leave tracks. 2-1/2” should be good enough.
Edit: pretty much be beveling both cutting edges of the iron so it doesn’t dig in. The edge will look something like this but not as exaggerated.
\__/
View jmartel's profile
jmartel
8013 posts in 2205 days
#2 posted 05-30-2016 02:56 AM
I freehand mine. It’s not so bad after a bit of practice. It definitely helps if you skew the iron 45 deg to the stone and direction of sharpening.
View BurlyBob's profile
BurlyBob
5656 posts in 2321 days
#3 posted 05-30-2016 03:14 AM
Wet and dry sand paper on a piece of granite.
View OSU55's profile
OSU55
1737 posts in 2045 days
#4 posted 05-30-2016 12:28 PM
Have you measured the jig? Looked at the jig manual for Veritas? If it won’t fit, get a #7 provided 2-3/8” fits. Here's the shop made jigs I use if you’re inclined to go that way. They allow the iron to be skewed on the stone.
BurlyBob
#5 posted 05-30-2016 03:10 PM
I sharpened my #8 type 17 blade with the Veritas jig. I’ve also used it with my 4 1/2’s, and 7’s. No Problem.
View sikrap's profile
sikrap
1121 posts in 3414 days
#6 posted 05-31-2016 03:59 PM
Yeah, I’ve done dozens of irons from 8’s in the MK II with no problem. Since you’re stones aren’t wide enough, I’d second the idea of the sandpaper on glass/granite/tablesaw/whatever.
-- Dave, Colonie, NY
View rwe2156's profile
rwe2156
3003 posts in 1536 days
#7 posted 05-31-2016 09:00 PM
-1 on grinding blade to match a stone
+1 for sandpaper w/jig
View JADobson's profile
JADobson
1100 posts in 2166 days
#8 posted 05-31-2016 10:19 PM
The Veritas mk ii guide will fit blades up to 2 7/8” wide: http://www.veritastools.ca/Products/Page.aspx?p=144
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
