Electrical Help on a Neon Transformer
« back to Coffee Lounge forum
Forum topic by Jim Jakosh posted 05-29-2016 12:00 PM 2593 views 1 time favorited 9 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
21736 posts in 3307 days
05-29-2016 12:00 PM
Topic tags/keywords: question
Are there any electricians among our group that know anything about neon light transformers? I have a Franceformer model 9030 9000 volt transformer and it has a ground fault circuit in it that shuts off the power when there is a short to ground somewhere. It works real well, but I plan to use it for Lichtenburg fractal burning which is taking the high side of the transformer to ground to burn wood. A direct short.
It has 5 wires coming out of the black mass around the windings going to this printed circuit box Two white, one black, one blue and one orange. I need to know which ones I can cut and maybe join to keep this puppy burning when shorted.
If this box is like a switch, there must be a power wire, a ground wire and a sensing wire coming to it and then two are the in and out of the switched wires. Anyone familiar with this type of circuit?
I have a note in to Franceformer but I’m not sure they will tell me.
Thanks, Jim
9 replies so far
View lew's profile (online now)
lew
12430 posts in 3957 days
#1 posted 05-29-2016 04:31 PM
Will this help- http://www.fusor.net/board/viewtopic.php?f=11&t=4919
Jim Jakosh
#2 posted 05-29-2016 09:05 PM
Thanks, Lew. That is exactly what I needed to know. I had an idea that the white wires were the ones that we being switched but was not sure.I don’t know how you ever found this but I was looking on the net for 2 days for this answer.
Removing GFI from a Franceformer.
Postby teslatron ยป Wed Mar 06, 2013 8:07 pm
I just acquired today a supposedly ‘DEAD’ 15KV 60MA Franceformer with GFI from a Neon Sign Builder. There was no ark generated from either side of the transformer when brought to ground. I found that unusual, because from my experience it is usually one side or the other that will go. So, I immediately suspected that the GFI circuit was faulty. At that point I was still suspecting that I would have to de-pot the transformer in order to remove the GFI. When I got home and set the Franceformer on the dining room table, I noticed a small access panel on the top surface directly above the red diagnostic switch. After removing the panel I could see that the GFI circuitry was accessible in its own compartment and contained no resin or tar. In order to access it however, I needed to remove the top cover. After doing that I removed the GFI by clipping the wires. There were two white wires, so I marked one of them prior to clipping. There was a black and white wire coming into the compartment together. I was assuming that these were line voltage piggybacks from the main power lugs on the opposite side of the Xfmer. Continuity testing confirmed my hypothesis. Using my understanding of wiring and what I thought was logical, I connected the two white wires together. The black wire I connected to the remaining two blue and orange wires. Then I powered up the transformer and crossed my fingers. I could hear a gentle hum coming from the box and to make a long story shorter, I was getting a nice arc to ground from both HV lugs.
Thanks again…............................Cheers, Jim
Jim Jakosh
#3 posted 05-29-2016 09:44 PM
Lew I made these changes and it worked right away. Thanks again. I’m in business!!!!!!!!!!!!!
That is why this site is so great!!!...............cheers, Jim
Here is what I did and also the result of the fractal burning also called wood lightning.
View rance's profile
rance
4266 posts in 3362 days
#4 posted 05-30-2016 03:48 PM
Looks great. Thanks for the info.
Jim Jakosh
#5 posted 05-30-2016 04:58 PM
Hi Rance. My thought is to use it on bowls!
Jim
View Joe Lyddon's profile
Joe Lyddon
10323 posts in 4254 days
#6 posted 05-31-2016 06:33 PM
I’m glad the solution was SO SIMPLE!
Jim Jakosh
#7 posted 05-31-2016 09:07 PM
Hi Joe, I knew it would be, but I wanted to be sure before I ruined a $100 transformer.
Cheers, Jim
rance
#8 posted 06-02-2016 10:03 PM
Jim, I nabbed two neon transformers a couple of years ago. You’ve sparked my interest again.
Jim Jakosh
#9 posted 06-03-2016 01:31 AM
Hi Rance. I think I burned mine out. It has now output. I’m taking it to a neon sign shop tomorrow to see if they have a way to test it.
So today I bought a microwave oven and dissected it for the transformer.It fires up real good but not the same pattern at all!
cheers, Jim
