Length of Kreg Screw
« back to Joinery forum
Forum topic by gdiddy13 posted 05-29-2016 02:22 AM 823 views 0 times favorited 6 replies Add to Favorites Watch
View gdiddy13's profile
gdiddy13
59 posts in 794 days
05-29-2016 02:22 AM
So here’s my issue (among others, but that’s for a different forum) I am connecting an apron to legs via Kreg screws.
My apron is 1 and 1/8 thick but I’m joining them to true 4×4 oak legs.
The longest Kreg screws I can get are coarse 2 1/5 long. Will this work, and if not what are other options?
Thank you!
View RussellAP's profile
RussellAP
3104 posts in 2337 days
#1 posted 05-29-2016 02:26 AM
For hardwood I’d use a screw with narrow threads, not the wide threads like decking screws. I pretty much use 1-5/8 for that kind of joint. If you can get furniture screws and some washers, they are really good for furniture. Don’t get philips head, get the square head, much easier to drive. Of course I should say that I rarely use the Kreg Jig, I just drill it manually, saves time.
gdiddy13
#2 posted 05-29-2016 02:28 AM
I should add that the longest Kreg screws I could get in the “fine threads” is 1 1/2”
I bought them, but not sure if I’ll use them
RussellAP
#3 posted 05-29-2016 02:30 AM
Seeing you’re drilling from the back of the skirt, you could just toenail a pilot hole and use them. I’d reinforce the legs with some bracing under the skirt too, use a good thick lag screw for that, and glue.
View devann's profile
devann
2246 posts in 2743 days
#4 posted 05-29-2016 03:37 AM
Here’s you some pictures of a table similar to what you’re doing. It has removable legs using a Kreg jig and screws. I used 3/4” aprons and 4×4 legs. It should give you some ideas. It’s held up well so far.
http://lumberjocks.com/projects/54425
View AlaskaGuy's profile
AlaskaGuy
4249 posts in 2360 days
#5 posted 05-29-2016 05:32 AM
Just because you used a Kreg jig to make pocket holes doesn’t mean you have to use Kreg screws.
Use any wood screw that fits the bill.
View TheFridge's profile
TheFridge
9693 posts in 1537 days
#6 posted 05-29-2016 05:37 AM
I’d just use a couple washers with any screw that has a bugle head. So it doesn’t split.
