Melamine usage question
Forum topic by DaveA posted 04-12-2010 07:46 PM 1293 views 0 times favorited 7 replies Add to Favorites Watch
View DaveA's profile
DaveA
46 posts in 3082 days
04-12-2010 07:46 PM
I did a utility room remodel with drywall, baseboards, etc. I have a concrete utility sink/washer discharge sink that now only has a brick wall behind it. I have been looking at various wall covering materials and found a 1/8” or ??mm thickness Melamine in a 4×8 sheet.
It did not say and I didn’t think to ask, but my question is: Is this material water proof or water resistant? I suspect it wouldn’t be more than a couple drops splashed from time to time.
-- Dave - Milwaukee
7 replies so far
View childress's profile
childress
841 posts in 3542 days
#1 posted 04-12-2010 08:25 PM
I think Melamine is….but be aware because there are products out there meant to look like melamine and they’re not. The only issue is the seems or joints. if water gets in there then there will be some swelling but as for the melamine itself, you can pour a glass of water on it and it will just sit there until it evaporates.
-- Childress Woodworks
View Michael Murphy's profile
Michael Murphy
453 posts in 3005 days
#2 posted 04-12-2010 08:41 PM
Just don’t let water get to the unsealed edges, it behaves like particle board or mdf then. Grades of melamine make a difference too. Domtar or Panolam would be better than the imports. When I was building kitchen cabinets we would always use matching laminate for the bottoms, sides and backs of sink cabinets or wherever water exposure could be a problem .
-- Michael Murphy, Woodland, CA.
View RedShirt013's profile
RedShirt013
219 posts in 3662 days
#3 posted 04-12-2010 08:45 PM
If there’s not much water you can PVC tape the edge to help a bit. Check out FRP panels (fibre reinforced plastic) for this purpose. Easy to clean and waterproof
-- Ed
DaveA
#4 posted 04-12-2010 08:48 PM
Thanks for the replys and the info on the joints. I didn’t think of that and there will be a joint below the upper edge of the sink. I can probably put a bead of silicone in the plastic union I’ll be using to join the two pieces together.
Edit: I considered the FRP, but the wife was opposed to the industrial/rest area bathroom wall decor in her new laundry room.
-- Dave - Milwaukee
View rep's profile
rep
95 posts in 3109 days
#5 posted 04-13-2010 09:59 PM
If you don’t want to use FRP – how about Formica (assuming you can get a piece large enough)?
-- rick
DaveA
#6 posted 04-14-2010 12:29 AM
I found the wall material that looks like tile as mentioned above. I think I’m going to use that. It will still have a horizontal seam in it behind the sink, so I will have to seal it, but it is attractive. My issue is I cannot use one continuous piece due to the plumbing and the plumbing off to the side for the wash machine hot and cold.
-- Dave - Milwaukee
View nailbanger2's profile
nailbanger2
1041 posts in 3143 days
#7 posted 04-14-2010 12:44 AM
Use Dens Armour! Cuts and attaches just like drywall, finishes the same also. It calls itself mold and moisture resistant, I call it impregnable. I was thinking about using it in my bath, but I didn’t know anything about it, so I took about 1 sq. ft. and put it in a bucket of water. Surprise, it floated! So I wedged a brick on top of it and figured I’d let it sit for a couple of days. Well, I forgot about it and got it out a week and a half later. It still snapped like it was brand new. Cut just the same also.
$12/ 4’ x8’ sheet. Don’t trust me, check it out yourself!
-- Wish I were Norm's Nephew
