band saw blade guard not moving perfectly straight?
Forum topic by dbw posted 05-28-2016 12:07 PM 886 views 0 times favorited 14 replies Add to Favorites Watch
View dbw's profile
dbw
207 posts in 1786 days
05-28-2016 12:07 PM
Topic tags/keywords: band saw blade guard
Folks,
I bought a Craftsman Professional 14” BS on CL. While tuning it up I noticed that the blade guard was moving straight up and down. Here is what is happening: the distance between the guide bearings and the blade changes as I raise/lower the blade guard. As I raise it the distance between the blade and the rear bearing increases, the distance between the blade and the left bearing decreases, and the distance between the blade and the right bearing increases. The opposite is true as I lower the guard. The guard appears to be straight and there is no binding through the entire travel. Does anyone know what causes this and, more importantly, how to fix it?
-- measure 3 times, cut once
14 replies so far
View Nubsnstubs's profile (online now)
Nubsnstubs
1408 posts in 1879 days
#1 posted 05-28-2016 02:50 PM
How does it cut, or have you tried that yet?.......... Jerry (in Tucson)
View dbw's profile
dbw
#2 posted 05-28-2016 03:08 PM
it cuts well. FYI there is no vibration and there are no weird noses. It runs smooth as silk. If I can solve this problem I believe I got a good saw especially since it’s a Craftsman.
View johnstoneb's profile
johnstoneb
3014 posts in 2322 days
#3 posted 05-28-2016 03:11 PM
That is one reason why they make the guide bearings and blocks adjustable. While it is desirable to be able to adjust once for a blade it isn’t always possible. Tune it to the best of your ability and you may be able to reduce the adjustments needed. Band saws are not precision instruments and there is slop almost everywhere. Usually a good tuneup will reduce or eliminate most of it.
-- Bruce, Boise, ID
View ArtMann's profile
ArtMann
1081 posts in 965 days
#4 posted 05-28-2016 05:15 PM
I have what I believe to be the same band saw, based on your comments. I will be perfectly honest. The saw is manufactured by Rikon and is cheaply made. The guard must be made to travel up and down exactly parallel to the blade and that takes some very careful shimming. Be prepared to take a few hours of trial fitting to get it right. I just leave mine set to 1.5 inch cutting height and adjust the guides for that setting. I only use this saw for curve cutting on 1 inch and thinner wood. I have another saw I use for resawing. By having two saws, I eliminate the tedious job of swapping blades all the time.
View dbw's profile
dbw
#5 posted 05-28-2016 05:41 PM
Thanks for your input. I’m going to set it and (almost) forget it until I change blades for resawing.
runswithscissors
2846 posts in 2174 days
#6 posted 05-29-2016 12:30 AM
I don’t understand what the blade guard has to do with your issue. Usually the blade guides are mounted on a post that goes up and down. It’s that post that should stay true and lined up as it moves. The guard is merely to keep you from cutting all your fingers off at once.
Maybe there’s something about the C’man that I don’t understand. Are the blade guides in fact mounted on the blade guard?
View RussellAP's profile
RussellAP
3104 posts in 2435 days
#7 posted 05-29-2016 02:37 AM
The post where the upper blade guide assembly rests can twist a bit when you raise and lower it. Mine used to have a ball bearing in it to keep it true, but that fell out when I installed a riser kit. Now I just give it a visual when I raise the bar to make sure it’s between the bearings.
View dbw's profile
dbw
#8 posted 05-29-2016 03:56 AM
Runswithscissors: the post is not running true. It moves in two directions as it is raised/lowered.
View mrg's profile
mrg
828 posts in 3148 days
#9 posted 05-29-2016 10:20 PM
You sure it’s the guard and not the blade that is cocked? If the the blade is angled on the wheels you will get the same thing, it doesn’t take much.
-- mrg
View dbw's profile
dbw
#10 posted 05-30-2016 05:08 AM
how can I check if it’s the blade vs. the post?
View mrg's profile
mrg
#11 posted 05-30-2016 01:26 PM
Take a square and place on the table behind the blade to see if it’s square to the table. If it’s not square in this direction your not tracking straight on the wheels. Readjust
I have this saw and it works ok for what I use it for. I’ll look to see if my guide is runs up and down straight. Does it straighten when you tighten it?
-- mrg
ArtMann
#12 posted 05-30-2016 05:37 PM
There is absolutely nothing you can do with the blade to make it travel in a different direction if the blade guides don’t travel up and down parallel to it. You must shim the rack and pinion assembly that goes up and down with the blade guides and guard. The tilt of the table has nothing to do with your problem.
how can I check if it s the blade vs. the post?
- dbw
View dbw's profile
dbw
#13 posted 05-30-2016 06:06 PM
I does not straighten when I tighten it.
View mrg's profile
mrg
#14 posted 05-31-2016 12:20 AM
I took a look at mine and the assembly has some play but goes up and down pretty much straight. When I get the bearings to the height and tighten the assembly straightens right out.
Look at the assembly as ArtMann suggested maybe you just need to adjust it. These machines are simple machines.
-- mrg
