Upcoming Grizzly Sale - Motor for Custom Sander?
Forum topic by Keith Kelly posted 05-27-2016 05:03 PM 565 views 0 times favorited 2 replies Add to Favorites Watch
View Keith Kelly's profile
Keith Kelly
263 posts in 1689 days
05-27-2016 05:03 PM
Last year, Grizzly had a pile of 50 or so motors for $25-75 (marked down from $200-400).
I primarily use my lathe as a freehand slowish-speed soft disc sander (faceplate + plywood + mousepad + sandpaper). I’m thinking it may be nice to have a standalone device for this purpose, so perhaps a basic rotating motor may be good.
For this use, what kind of specs should I look for? My assumption is a slower one, like 1750 RPM so I don’t have to reduce it as much with pulleys, and that 1/3hp or lower would be ideal.
(heck, I might just look for another benchtop lathe…this one came from last year’s tent for $65)
Is there anything in particular I ought to look for in the pile of motors for this sort of purpose?
-- Keith - Bolivar, Missouri, http://www.SquareOneWoodworks.com
2 replies so far
View HokieKen's profile
HokieKen
5246 posts in 1164 days
#1 posted 05-27-2016 05:12 PM
I think the motor is largely dependent on the disk size. The larger the disk, the faster it will be turning at it’s outer edge. So for a large disk (16-20”), you might need a 1/2 hp stepped down to around 1.5:1. I’d say for 8-12” a 1/3 hp 1750 rpm motor would be good for directly driving the disk or with 1:1 pulley ratio.
-- Kenny, SW VA, Go Hokies!!!
Keith Kelly
#2 posted 05-27-2016 05:24 PM
ok, thank you, that was helpful.
