Magnetic switch ? for the electrically knowledgeable
Forum topic by AandCstyle posted 05-27-2016 03:32 PM 943 views 0 times favorited 12 replies Add to Favorites Watch
View AandCstyle's profile
AandCstyle
3164 posts in 2402 days
05-27-2016 03:32 PM
Topic tags/keywords: question
I couple weeks ago I mentioned that I seemed to be having a lot of electrical issues. I briefly mentioned my table saw while asking about my sander. The table saw finally completely died and I found the out that the switch was the source of the issue. I replaced the switch and the TS ran fine for the test run, but my question is why it shorted out in the first place? At least, it looks like a short to me. Whatever the cause, I would like to know so I can avoid a recurrence. Thanks!
-- Art
12 replies so far
View Loren's profile
10477 posts in 3792 days
#1 posted 05-27-2016 03:45 PM
The copper contacts on mag switches get corroded over
time with use. To some extent the can be cleaned but
eventually they get mis-shaped and don’t make a good
contact, so they chatter on start up and eventually cook
the switch.
In a way that’s the idea I think. The switch gets smoked,
not the rest of the electrics. On more specialized industrial
machines the wiring can be pretty sophisticated for code
reasons and very much a PITA to repair if damaged.
I smoked a worn magnetic switch on a 7.5hp wide belt
sander by starting the machine using a 5hp phase converter.
Lesson learned. I upgraded to a bigger phase converter
and replaced the magnetic contactor. Switches and
contactors can be got pretty reasonably on ebay, shipped
from Asia. The tricky part is figuring out what current
Asian model is right to replace a 30 year old one.
View splintergroup's profile
splintergroup
2304 posts in 1367 days
#2 posted 05-27-2016 04:38 PM
Art, it’s hard to fully diagnose over a single photo, but based on the usual mode for these kind of failures Loren is correct.
The damage in the photo looks to be heat related in the sense that a dead short somewhere would trip a protective breaker and not damage the wiring as bad. High resistance from a bad contact will cause things to heat up significantly, but not trip any protective devices. Your melty mess probably means the contacts got hot enough to start the ball rolling. This is a good example of why it is imperative to have a properly grounded tool.
MrUnix
6931 posts in 2343 days
#3 posted 05-27-2016 05:19 PM
The damage in the photo looks to be heat related [...] High resistance from a bad contact will cause things to heat up significantly, but not trip any protective devices.
- splintergroup
That is exactly what it looks like. Typically caused by a loose or not fully secured wire or one that was undersized for the application. They can also get loose over time simply due to the thermal expansion/contraction of the wire each time the machine is used (and one reason copper wire is typically used as opposed to something like aluminium, which has a much higher thermal expansion rate).
View muleskinner's profile
muleskinner
897 posts in 2581 days
#4 posted 05-27-2016 05:34 PM
Dirty, corroded or loose contacts cause resistance and arcing which end up with what you got there. A little fine wood dust and a little moisture are probably pretty common culprits in a woodshop. A guy should probably blow out the starters on his equipment every once in a while. And I should probably make a note to myself to do that sometime.
-- Visualize whirled peas
View Grumpymike's profile
Grumpymike
2310 posts in 2460 days
#5 posted 05-27-2016 09:02 PM
Muleskinner Hit it on the head resistance ... Each time the switch is turned off or on there is a small arc, leaving behind a small bit of carbon. Carbon is a resistor. A resistor in a circuit causes heat. More carbon (and other gunk) equals more heat until … China Syndrome and melt down.
How to avoid a switch failure? Just don’t use it. Like any electro-mechanical part there is failure … like a bearing wearing out.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
View clin's profile
clin
929 posts in 1141 days
#6 posted 05-27-2016 09:25 PM
How to avoid a switch failure? Just don t use it. Like any electro-mechanical part there is failure … like a bearing wearing out.
- Grumpymike
Some contact types actually rely on that small arc to keep the contact clean. But as all are saying, contacts do wear out and high resistance means heat.
Another possible issue is the connection of the wire to the switch. If this loosened up, you can also get a high resistance and heat. No different than a poor connection in house wiring.
Probably not a bad idea for any of us to periodically check those power connections in large machines, like table saws, and certainly if something is acting up.
-- Clin
View MadMark's profile
MadMark
979 posts in 1597 days
#7 posted 05-27-2016 10:08 PM
The terminal crimp wasn’t correct …
M
AandCstyle
#8 posted 05-27-2016 11:43 PM
Thanks for the replies. My take away is that the switch is a part that is expected to wear out and has to be replaced periodically. That is fine, I just wanted to be certain that it wasn’t due to something that I am improperly doing.
Again, thank you!
-- Art
runswithscissors
2843 posts in 2170 days
#9 posted 05-28-2016 04:48 AM
I could be flat out wrong about this, but I thought carbon was a conductor, not a resistor. Like the carbon brushes in a universal motor.
Not that that has any bearing on your switch problem.
View TheFridge's profile
TheFridge
10304 posts in 1631 days
#10 posted 05-28-2016 05:11 AM
Pull it apart. It may be salvageable believe it or not. As long as the plastic support structure isn’t deformed or the contact pad isn’t burnt through. If it’s not salvageable just find you another IEC contactor with the same specs.
View Rentvent's profile
Rentvent
151 posts in 993 days
#11 posted 05-28-2016 05:53 PM
I agree with MadMark – it looks like the crimp was bad.
AandCstyle
#12 posted 05-28-2016 11:48 PM
Thanks for the responses.
-- Art
