Tablesaw Blade Out of Allignment - Help Please
Forum topic by fsutim posted 05-27-2016 04:21 AM 568 views 0 times favorited 2 replies Add to Favorites Watch
View fsutim's profile
fsutim
17 posts in 1222 days
05-27-2016 04:21 AM
My table saw blade is not evenly parallel to the throat plate on my Dewalt saw. See attached picture, it starts to runout about halfway down the length of the blade. Any ideas on how to troubleshoot this? Also, any idea how this would impact my cuts if I’m using the fence for ripping wood with a tablesaw jointer jig for glueups? I appreciate any insight!
2 replies so far
View MrUnix's profile
MrUnix
6887 posts in 2316 days
#1 posted 05-27-2016 04:25 AM
Alignment of a throat plate is meaningless and not something you should be overly concerned about. The miter slot should be aligned to the blade, and the fence should be aligned to the miter slot. The throat plate does not play a part in that equation. If it bugs you and everything else is in alignment, then you can just make a new throat plate or two.
View TheFridge's profile
TheFridge
10096 posts in 1603 days
#2 posted 05-27-2016 04:33 AM
Ditto
