kitchen cabinet doors
Forum topic by plang posted 04-11-2010 08:11 PM 1347 views 0 times favorited 7 replies Add to Favorites Watch
View plang's profile
plang
117 posts in 3323 days
04-11-2010 08:11 PM
My wife wants me to build new doors for our kitchen cabinets and wants them to have beadboard as the paneling to match a spice cabinet I made for her. My question is, what other joints will serve well on the rails and stiles other then cope and stick. I have no way at this time to make anything fancy due to my shop is in storage. At this time it will need to be something simple such as a 45 degree with spline at the joints, or her choice, a half lap joint which I agree to for strength. Will these joints hold up for this application or what do you suggest? Thanks Plang
7 replies so far
View bigike's profile
bigike
4050 posts in 3256 days
#1 posted 04-11-2010 08:29 PM
toung and groove. (spelling?) sorry you did say other than cope and stick too, so what about plunge panel bits? ;)
View gbvinc's profile
gbvinc
628 posts in 3915 days
#2 posted 04-11-2010 10:01 PM
A half lap would work and you could fancy it up by a small rounding where the boards meet, if desired.
View davidpettinger's profile
davidpettinger
661 posts in 3168 days
#3 posted 04-12-2010 12:17 AM
Pocket screws with butt joints will also work on the door and are amazingly strong. You can rabbet the backside of the door panel frame to install the bead board panel. Won’t be fancy, but will definitely won’t require a lot of tools.
-- Methods are many,Principles are few.Methods change often,Principles never do.
View Michael Murphy's profile
Michael Murphy
453 posts in 2973 days
#4 posted 04-12-2010 12:51 AM
Mitered doors with splines or biscuits along with the beadboard should be strong enough and easy to do.
-- Michael Murphy, Woodland, CA.
View CaptainSkully's profile
CaptainSkully
1591 posts in 3526 days
#5 posted 04-12-2010 05:00 PM
Half-lapping the rails and stiles will be plenty strong for your application. A simple rectangular cross-section will work nicely with the beadboard panels. They’re simple to make, and if they’re all the same thickness and width, you can crank all of them out with a single setup.
-- You can't control the wind, but you can trim your sails
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3254 days
#6 posted 04-13-2010 11:56 PM
This is a little more time consuming but makes a good strong joint with minimal tools. I have doweled mitered corners together several times. All you need is a drill and doweling jig. I have not had great luck with biscuits and strong joints.
Half lap is a good choice, but do you have the tools available to do that?
-- http://shepherdtoolandsupply.com/
View David "Lucky Dawg" Brown's profile
440 posts in 2960 days
#7 posted 04-14-2010 12:06 AM
Check out Copperhead’s page on LJ’s He is a cabinet door maker
and knows his stuff! I met him last week and saw his business!
I’m sure he could help you!!!!!!
-- dumpster diver delux
