Joining Rounded legs onto 90 degree mitre corner?
« back to Joinery forum
Forum topic by RogueRobot posted 05-26-2016 01:28 PM 759 views 0 times favorited 12 replies Add to Favorites Watch
View RogueRobot's profile
RogueRobot
6 posts in 786 days
05-26-2016 01:28 PM
Topic tags/keywords: question joining
Hi all,
I’m in a sticky situation. I’ve designed the following upper table:
Here is a closer look at the part i’m having trouble with:
The leg (top and bottom has a diameter of 22mm):
My main question:
I have no idea how to join the leg onto the mitre corner. The overhang is 6mm, however I can make it flush with the bottom of the table.
My only idea is to get a circular tubed bracket (similar to type below) and screw it on.
(http://products.ironcdn.co/992009.jpg?w=170&quality=80&ts=2552016).
Tools, or budget isn’t a problem. But time is (about 1 week and 1-4 hours a day to do the join)
Thanks in Advance.
12 replies so far
View gargey's profile
gargey
1010 posts in 831 days
#1 posted 05-26-2016 01:52 PM
Beautiful table! Good job
View waho6o9's profile
waho6o9
8242 posts in 2632 days
#2 posted 05-26-2016 01:52 PM
Make a center finder:
http://lumberjocks.com/search_results?cx=017914489645407774653%3Agwwk-zif3wk&cof=FORID%3A9&safe=high&q=shop+made+center+finder&sa.x=0&sa.y=0
Handsawgeek made an effective one:
Get some threaded inserts and matching threaded rods ( or carriage bolts)
5/16×18 tpi (thread per inch) etc…
And have some fun.
waho6o9
#3 posted 05-26-2016 01:57 PM
Or, you can use these:
View chiseler's profile
chiseler
124 posts in 944 days
#4 posted 05-26-2016 11:07 PM
you could change your design and turn your legs with pommel to accept aprons.because no matter what you do in that situation the table won’t be very stable
-- Scott.Triangle,NY Becareful and don't forget...They cut meat too! Ask me how I know
View conifur's profile
conifur
955 posts in 1207 days
#5 posted 05-26-2016 11:29 PM
Best bet is to leave the upper part of the legs square to mate in with the aprons, then your fastener choices will increase and strength. What is the top?? Not flat? what kinda table is that?
View Aj2's profile
Aj2
1509 posts in 1853 days
#6 posted 05-27-2016 01:50 AM
It’s a design that needs refinement.Conifer has a good suggestion
The legs will be too weak if it’s in a area were people will walk up to it a leg might get kicked.Thats gonna be a problem.
Good for you thinking out of the normal.
-- Aj
RogueRobot
6 posts in 786 days
#7 posted 05-30-2016 09:45 AM
- conifur
it’s hard to see, but there is glass on top. The ‘wierd things’ are balustrades- the poles between railings on deckings.
RogueRobot
6 posts in 786 days
#8 posted 05-30-2016 10:02 AM
It s a design that needs refinement.Conifer has a good suggestion
The legs will be too weak if it s in a area were people will walk up to it a leg might get kicked.Thats gonna be a problem.
- Aj2
it’s going to hold coffee, small plates, etc.
Won’t be kicked. I forgot to mention it will be sitting on a lower table;
the full thing:
Sorry about the angles, these are the only pictures I had before my CAD software licence ran out today (even though I renewed it last month for a year…)
The two tables are going to come apart- it’s a key feature for the table.
This is a school project, all being made for a real client (last year of school, I’m doing Product Design and Technology)
RogueRobot
6 posts in 786 days
#9 posted 05-30-2016 10:06 AM
- waho6o9
A double ended screw would be really useful- especially since I missed some details (see images above)
View Ger21's profile
Ger21
1075 posts in 3186 days
#10 posted 05-30-2016 11:49 AM
it s going to hold coffee, small plates, etc.
Won t be kicked.
Without drastically changing the design, I’d use dowel screws like the previous poster showed. The bigger, the better.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
RogueRobot
6 posts in 786 days
#11 posted 05-31-2016 11:06 AM
Thanks for the help everyone. I’ll use dowel screws to hold it together. I’ll create a separate thread once it’s finished
RogueRobot
6 posts in 786 days
#12 posted 05-31-2016 11:12 AM
