Quick question about angles for an equilateral triangle raised garden bed
Forum topic by hypnos posted 04-11-2010 12:39 AM 9318 views 0 times favorited 4 replies Add to Favorites Watch
View hypnos's profile
hypnos
28 posts in 3312 days
04-11-2010 12:39 AM
I should have paid more attention in geometry class. I have three 2×10 10’ boards, what angle should I cut on one end of each board with my circular saw to make an equilateral triangle?
Thanks!
-- David P., Kansas City
View Les Casteel's profile
Les Casteel
160 posts in 2933 days
#1 posted 04-11-2010 01:09 AM
any triangle contains 180 degrees total. so 180/3 = 60 for each intersection. Then 60/2 =30 so you cut each board on the ends at 30 degrees.
Good Luck!
-- Les, Missouri, www.woodthatrocks.com
View Wood_smith's profile
Wood_smith
257 posts in 2898 days
#2 posted 04-11-2010 01:09 AM
but wouldn’t you cut both ends of each board?
-- Lloyd Kerry; creator of the Kerry-All Pouch, http://www.kerrywoodworking.com
13594 posts in 3214 days
#3 posted 04-11-2010 01:11 AM
if you want to overlap them , 30 deg all ends ,
shopgirl is right , 60 deg is right for a miter .
all triangles equal 180 deg inside .
your picture didn’t show for a while shopgyrl ,
so i edited mine .
hypnos
#4 posted 04-11-2010 01:25 AM
Yeah, I figured out 30 degrees on the saw would do it if I cut each of the ends, I was envisioning somehow being able to just cut one end on each board so I’d be able to drive screws through a face into end grain, being able to drive as long of screws as I want – just cutting one end of each end. That’s what had me a little stumped seeing the angles. I may just have to cut each end and rely on a triangular post between each point to drive the nails in…
-Edit I just refreshed and saw the first triangle you posted shopguryl – that’s what I was thinking, except I thought I could somehow leave one end uncut, I see that would blunt the points of the triangle.
