differences between Denatured Alcohol brands
Forum topic by trsnider posted 05-26-2016 01:13 AM 775 views 0 times favorited 7 replies Add to Favorites Watch
View trsnider's profile
trsnider
72 posts in 2132 days
05-26-2016 01:13 AM
This should probably be an FAQ. Is there any real difference between using a DA from a big box store that has 40-60% Ethanol vs one that has ~90%? I’ve decided to branch out from the “big Z” and mix my own. I’ll only mix enough to use so I won’t be storing it for a long period.
7 replies so far
View splatman's profile
splatman
586 posts in 1521 days
#1 posted 05-26-2016 02:22 AM
If you mix your own, why not 100% Ethanol instead? Denatured alcohol is so-called because it has additives to render it non-drinkable (according to Wikipedia).
How it functions as a solvent would likely depend partly on the non-ethanol ingredients.
View TheFridge's profile
TheFridge
10141 posts in 1608 days
#2 posted 05-26-2016 02:26 AM
I’ve only recently heard of folks using everclear.
View conifur's profile
conifur
955 posts in 1273 days
#3 posted 05-26-2016 02:47 AM
I ve only recently heard of folks using everclear.
- TheFridge
A friend makes guitars, thats all he will use to mix his Shellac.
View jdh122's profile
jdh122
1035 posts in 2939 days
#4 posted 05-26-2016 05:37 PM
I wouldn’t use alcohol that was less than 90% to dissolve shellac. I haven’t tried to use the lower proportions, but have read several times in finishing books that you shouldn’t, and it makes sense to me because if you have 40% DNA you have a lot of water in the rest of it, which will hinder the drying of the shellac.
-- Jeremy, in the Acadian forests
TheFridge
#5 posted 05-26-2016 05:52 PM
I’ve read on many sites that 90% alcohol or better is what to buy. Any less and you risk blushing and whatnot.
View MNgary's profile
MNgary
303 posts in 2539 days
#6 posted 05-27-2016 03:49 AM
Sunnyside brand denatured alcohol only has 5% water. The balance is a combination of ethanol and methanol. Coincidentally I phoned and talked to their engineering department this morning. I had to know so I could mix flattening/softener for veneers.
-- I dream of a world where a duck can cross the road and no one asks why.
TheFridge
#7 posted 05-27-2016 04:30 AM
Doesn’t sherwin Williams sell that brand? Do you know?
