Router table lift
Forum topic by BlackIrishman posted 05-25-2016 03:12 PM 930 views 2 times favorited 13 replies Add to Favorites Watch
View BlackIrishman's profile
BlackIrishman
4 posts in 732 days
05-25-2016 03:12 PM
Topic tags/keywords: router lift router router table question
Anyone have a recommendation for the best router lift for the $? I have seen mixed reviews of the rockler lift fx which seemed reasonably priced.I just don’t really or just trust some of these online forums because fan boys and haters will bash anything whether they have actually owned it and used it or not. The most common complaint I have seen is that the vibration will make the bit float. I guess what I am asking is… is there a good rig under $200? I have a dewalt 618 for reference of my search. And if not, what would you recommend?
13 replies so far
View bonesbr549's profile
bonesbr549
1549 posts in 3067 days
#1 posted 05-25-2016 03:18 PM
Woodpecker PRL. Had mine for over 10 years and its flawless and I pound the heck out of it
http://www.woodpeck.com/prlv2.html
View Lazyman's profile
Lazyman
1965 posts in 1387 days
#2 posted 05-25-2016 03:45 PM
I don’t have one yet but there are some interesting DIY designs out there that seem to work pretty well that’ll definitely fit under the $100 level. Woodsmith (or was it ShopNotes) magazine has a simple design that you can see executed on Steve Ramsey’s YouTube channel. Jay Bates, Mathias Wandel and Stumpy Nubs each have mulitple designs worth looking at. You can probably find various examples of DIY lifts here on LJ as well. I’ve been thinking about making one myself for a while now—just hasn’t risen to the top of my to-do list.
View MadMark's profile
MadMark
979 posts in 1453 days
#3 posted 05-25-2016 03:58 PM
I have a Milwaukee 3hp router on a plate, the plate & router lift out for access and the plunge release button removes the base instantly for perfect access to the bit collets. A DRO bit height gauge makes setting bits a snap.
M
View dschlic1's profile
dschlic1
428 posts in 1969 days
#4 posted 05-25-2016 04:39 PM
I second the idea of the ShopNotes router lift. I built one and works great. Made two small changes to the basic design. First the support for the router motor was split into two pieces giving a wider clamping base for the router. Second I made a brake for the lead screw to stop it from turning.
Very accurate, I have made dovetail joints with it using the INCRA jig. Dovetail joints using this method require very precise height adjustments (on the order of thousandths of an inch).
View HokieKen's profile
HokieKen
5014 posts in 1138 days
#5 posted 05-25-2016 05:31 PM
I put a Router Raizer on my PC 7539 and I’m tickled with it. Less than $100, took me about an hour to install and now I have above the table adjustment with no major changes to my table or mounting plate. Not the nicest lift out there by any means but dollar-for-dollar, I think it’s hard to beat.
-- Kenny, SW VA, Go Hokies!!!
View Tugboater78's profile
Tugboater78
2743 posts in 2192 days
#6 posted 05-25-2016 06:35 PM
- dschlic1
Has this on my todo list for some time but not sure what kind of plate i should get. A blank plate with just the hole for bits or one designed for a specific router. The router i likely will be mounting is a Cman prof 2.5 hp.
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
HokieKen
#7 posted 05-25-2016 06:54 PM
Tugboater,
I recommend the Kreg plate. Only because it’s the only one I’ve ever had and because it’s remained flat and solid. There are many good plates out there though, it’s just a matter of how much you want to spend and how heavy your router is. Blank or pre-drilled doesn’t really matter – depends on whether you’re comfortable drilling your own holes.
View KelleyCrafts's profile
KelleyCrafts
2832 posts in 739 days
#8 posted 05-25-2016 07:25 PM
I built this one: http://www.ibuildit.ca/Workshop%20Projects/router-lift-1.html
Works awesome, no complaints, fun build, accurate as anything else, use it often. Mounted to the end of my table saw with an incra plate. No holes in the plate, can change bits top side with the two wrench setup without a special wrench.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
View Redoak49's profile
Redoak49
3248 posts in 1988 days
#9 posted 05-25-2016 08:54 PM
I have a Woodpecker lift with a PC 7518. I have had it for years and never thought about wanting something else. Woodpecker lifts are not cheap but a terrific long term value.
View jar944's profile
jar944
127 posts in 1437 days
#10 posted 05-25-2016 09:08 PM
Not really sure for under $200. I have the jessem mast-r-lift ii I picked up off of Amazon during a sale for $229.
It’s well built and solid. Though I don’t think I’d pay full price.
View lew's profile
lew
12061 posts in 3755 days
#11 posted 05-25-2016 09:15 PM
Several years ago, Woodsmith (or maybe ShopNotes) published the plans for making one. Mine has been working great. The only problem I had was I could not find the threaded rod speced in the plans and went with a different tpi rod.
Lazyman
#12 posted 05-26-2016 01:57 AM
I went and found the Shopnotes issue. # 121
Here is a picture of the cover.
You can buy the plans here:
http://www.woodsmithplans.com/plan/router-jig-router-lift/
BlackIrishman
4 posts in 732 days
#13 posted 05-26-2016 09:32 PM
Thanks for all your replies everyone! I am new to this community but I am digging the insight. I think I am going to build one as of now.
