Help with end grain cutting board cracking problems
Forum topic by indychip posted 05-25-2016 11:17 AM 1282 views 0 times favorited 6 replies Add to Favorites Watch
View indychip's profile
indychip
81 posts in 2324 days
05-25-2016 11:17 AM
I just completed several end grain cutting boards for a customer. This morning I woke up and noticed a bunch of little cracks all over the end grain. What happened? Could the wood have been too wet when I glued up and cracked when it began to dry? Is it time to buy a moisture meter?
View Tennessee's profile
Tennessee
2893 posts in 2717 days
#1 posted 05-25-2016 12:24 PM
Seems like you’ve answered your own question.
I don’t know what the moisture content of your wood was, but obviously it was too high for the application.
I keep two moisture meters on my bench, and use them often. Many times I re-rack a piece of lumber if it is too high.
19452 posts in 2059 days
#2 posted 05-25-2016 12:36 PM
Were you using different kinds of wood, possibly one that was much drier than the other. As the wetter one dried it would not be able to shrink and would crack.
indychip
#3 posted 05-25-2016 05:14 PM
Thanks for the responses. I was using multiple types of wood. The only one with cracks was the walnut. Obviously that was too wet.
I see different types of moisture meters. Pin type and non pin type. Which is best?
#4 posted 05-25-2016 06:18 PM
Pin type you push in and get a better measurement of the interior wood.
View Aj2's profile
Aj2
1881 posts in 2001 days
#5 posted 05-25-2016 10:46 PM
When you built them did you clamp the c**p out of them to close up gaps.And add lots of glue that’s s mostly water.
I’m just thinking if you started with high mc wood you would have noticed before you got this far.
-- Aj
View Kelly's profile
Kelly
2134 posts in 3147 days
#6 posted 05-26-2016 04:33 PM
oil, oil, oil (non-hardening (mineral oil))
Don’t wipe it off. Let is soak in.
I’ve done this to end grain butcher blocks and it swelled the wood up and closed the separations and cracks. Since the oil doesn’t evaporate, you just keep adding to, eventually, saturate the wood. With oil replacing the lost moisture, the block won’t shrink, thus will not crack and split.
Of course, you have to be mindful of that your customers may not be too hot on maintenance, so your project may go south after the fact.
