Micro-Mesh Pen Sanding Kit - Cleaning
Forum topic by LarryDNJR posted 04-09-2010 08:05 PM 1859 views 0 times favorited 1 reply Add to Favorites Watch
View LarryDNJR's profile
LarryDNJR
209 posts in 3335 days
04-09-2010 08:05 PM
I am using the Micro-Mesh Pen Sanding Kit from Woodcraft http://www.woodcraft.com/Product/2005233/10573/Micro-Mesh-Pen-Sanding-Kit.aspx. I was wondering if anyone had any suggestions on cleaning? Only thing I can find is use a stiff plastic brush. I was curious is there a soap option, toss them in the washer, any chemicals preferred. I tried using a stiff brush but my main problem is some black paint that got off some 7mm bushings worked itself into the pads some and it doesn’t just scrub off.
-- ~Larry Columbus, OH
1 reply so far
View PetVet's profile
PetVet
329 posts in 3728 days
#1 posted 04-09-2010 08:27 PM
I just use soap and water to clean them. Also, I use them wet, that helps cut down on the clogging you are experiencing. If you have paint on one, you might try the paint solvent or gum off to see if it will dissolve.
(Go Bucks!)
-- Rich in Richmond -- Experience is something you don't get until just after you need it.
