attaching table top fasteners
Forum topic by gdiddy13 posted 05-23-2016 03:16 PM 953 views 0 times favorited 16 replies Add to Favorites Watch
View gdiddy13's profile
gdiddy13
59 posts in 769 days
05-23-2016 03:16 PM
I think I’m in the right forum.
I have decided that I will be using table top fasteners to attached a reclaimed barn door to the apron.
Currently I do not own a bench saw, ( I know).
The option I thought of (as I’m doing all joints by hand) is to simply chisel out each slot for the fastener?
Thoughts? What might be another way?
16 replies so far
View muleskinner's profile
muleskinner
896 posts in 2462 days
#1 posted 05-23-2016 04:04 PM
I’m trying to envision how you’d accomplish that with a miter saw.
-- Visualize whirled peas
gdiddy13
#2 posted 05-23-2016 04:13 PM
haha, yep nevermind. I guess on a very small end table or something that might work. I’m going to go back and edit this post!
View pintodeluxe's profile
pintodeluxe
5705 posts in 2839 days
#3 posted 05-23-2016 04:19 PM
I would rethink the use of those tabletop fasteners that fit into slots. Yes they allow wood movement, but sometimes you feel like the top will slide around or fall off (especially when moving the furniture). I much prefer figure 8 fasteners. Skip the hollow stamped metal ones, and look for the solid steel ones. My local woodworking store sells them in bulk. Available at Lee Valley and elsewhere.
Use these…
not these…
gdiddy13
#4 posted 05-23-2016 04:23 PM
Good idea, these would be able to pivot a bit to allow for movement too.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2395 days
#5 posted 05-23-2016 05:14 PM
You could cut the slots with a router or bisuit joiner if you have either of those. I get my table top fasteners from cshardware.com for a few cents apiece.
If that’s not an option, another option would be gluing blocks to the inside of the apron, and drilling oversized holes in those blocks to allow for movement. Then, just screw up through them into the table top.
gdiddy13
#6 posted 05-23-2016 05:28 PM
I may have access to a router, and that would be a no-brainer! I think that maybe I shouldn’t be on here quite yet, I am really inexperienced. Thanks guys!
BinghamtonEd
#7 posted 05-23-2016 05:35 PM
I may have access to a router, and that would be a no-brainer! I think that maybe I shouldn t be on here quite yet, I am really inexperienced.
- gdiddy13
No experience necessary (however if you’re going to use the router, some experienced guidance wouldn’t be a bad idea), and if you stick around, chances are you’ll progress faster. You can set the router up with an edge guide (or on a router table if available) with a straight bit, and cut the groove down the apron.
I haven’t found like the tops feel like they’re going to move when using them, you don’t need to leave them that loose. I usually space them one every foot or so, or a minimum of two per side, on all four aprons.
View jumbojack's profile
jumbojack
1677 posts in 2650 days
#8 posted 05-23-2016 05:39 PM
I usually use the blocks glued to the apron approach as above. Simple effective and nearly cost free.
View Dan Wolfgang's profile
Dan Wolfgang
174 posts in 833 days
#9 posted 05-23-2016 07:17 PM
Yep, I just recently did this with a chisel. I think they’re about 3/32” thick, so I just used an 1/8” chisel to cut a small slot—big enough that it can move, about an inch long, I think.
View gfadvm's profile
gfadvm
14940 posts in 2716 days
#10 posted 05-24-2016 12:34 AM
I use the figure 8 fasteners for their cost, ease of use, and the only way to screw them up is to use screws that are too long (don’t ask how I learned this!)
gdiddy13
#11 posted 05-25-2016 12:23 PM
For those of you that used the figure 8 fasteners, did you use a forstner bit ?
18351 posts in 1882 days
#12 posted 05-25-2016 12:48 PM
A forstner bit is the only way to go. You need a flat bottomed hole.
gdiddy13
#13 posted 05-25-2016 01:17 PM
thanks guys, I’m hoping to have it ready to put together this weekend. I’ll try to post some pics to prove I’m not completely inept (only partially)
View Mike_D_S's profile
Mike_D_S
478 posts in 2240 days
#14 posted 05-25-2016 01:50 PM
If you use the forstner (router would also be a great option), then my only comment is one note about the picture above showing the pressed metal one. I know the pic is supposed to show which one not to buy, but I’ll also point out the way it is installed in a hole that is exactly the size of the fastener and with the wood fitting tightly against the narrow “neck” of the figure eight is in my opinion not the way to do these.
To allow for wood movement, these need to be able to move some small mount even if it’s only 1/32 of an inch. Having the figure eight captured is probably not going to cause any real problems as the wood will probably get distorted around the fastener since it’s a sharp point. But is offends my sensibilities to not clean up the end of the hole with a chisel so the figure eight mount has a bit of clearance to rotate to allow for wood movement.
Mike
-- No honey, that's not new, I've had that forever......
gdiddy13
#15 posted 05-25-2016 01:55 PM
Great point Mike! I’ll be using an 11/16 bit and plan on doing just as you said with a chisel.
