band saw wheel run-out
Forum topic by dbw posted 05-23-2016 02:09 PM 648 views 0 times favorited 5 replies Add to Favorites Watch
View dbw's profile
dbw
184 posts in 1510 days
05-23-2016 02:09 PM
Topic tags/keywords: band saw wheel
What is y’alls opinion on acceptable band saw wheel run-out front to back (lateral?) I haven’t measured mine yet but I think one or both wheels are wobbling a bit because I can see the blade going back and forth as it’s running when viewed from the side. Could the blade itself be wabbly? The blade is a Olson 1/2” X 3tpi.
-- measure 3 times, cut once
5 replies so far
runswithscissors
2602 posts in 1898 days
#1 posted 05-25-2016 04:04 AM
Could be an imperfect weld, which could cause the effect you are seeing. Have you checked the wheels without the blade on to see if you might need new bearings.
View TheFridge's profile
TheFridge
8660 posts in 1359 days
#2 posted 05-25-2016 04:24 AM
I’d lean towards bad weld. Especially if it’s a lower end blade. I’ve bought nothing but cheap ones and they’re pretty much all like that.
View dbw's profile
dbw
#3 posted 05-25-2016 01:04 PM
I measured the run-out of the top wheel. It’s .008 TIR.
View HokieKen's profile
HokieKen
4594 posts in 1012 days
#4 posted 05-25-2016 06:29 PM
I’d say it’s the blade. .008 TIR shouldn’t cause enough movement of the blade for it to be visually evident at the table. Stick your indicator on the back of the blade and see if it moves gradually or all at once. If it’s all at once, it’s a bad blade weld. Obviously, do this by turning one of the wheels by hand, not with the bandsaw running ;P
-- Kenny, SW VA, Go Hokies!!!
View dbw's profile
dbw
#5 posted 07-10-2016 12:29 PM
It turns out the lower wheel bearings and the tension adjustment pulley bearings where part of this issue. The friction got so bad that eventually the drive belt broke. I replaced the bearings with the sealed version.
