Mobile Base -Pivoting Bed for Carver
Forum topic by Kelly posted 05-23-2016 01:08 AM 537 views 0 times favorited 2 replies Add to Favorites Watch
View Kelly's profile
1939 posts in 2874 days
05-23-2016 01:08 AM
Topic tags/keywords: radio carver pivoting bed carver portible portable table bed router carve carving mobile mobile base router carver carving machine duplicator
I bought this caver on a maple butcher block counter top, which weighed in at around one hundred pounds or so. Add the carver and a base and the entire thing weighed in around a couple hundred pounds. Obviously, it wasn’t very portable.
I wanted the unit to be portable, and to not take up a huge amount of space, when not in use. To that end, I made a box similar to what some would call a torsion box [then donated the butcher block to projects]. Once that was done, my plan was to make the table pivot using some swing set pipe I salvaged from a friends swing set (they were probably going to throw it out anyway).
The box works well. I made it large enough to allow me to install a sliding carriage and to install wider support rods.
Today, I some time out and built the portable base portion. It rolls easily and and pivots well. With about twenty more pounds on the top, it should be fairly counterbalanced. Even as it is, my wife can tip it.
In the upright position, it only takes up about fifty inches by about thirty inches.
It feels very stable, when dropping it down to the storage position.
I won’t do anything to adjust the balance yet, since I still have carriages and things to play with.
I had planned on adding telescoping legs at each corner, but, in use, it feels solid with just a single support at the center of each end.
I still have some detailing to do (e.g., cut the pipe to length), but, over all, I’m pretty happy with the results of today’s efforts.
2 replies so far
View splatman's profile
586 posts in 1329 days
#1 posted 05-23-2016 03:13 AM
The title has got me. If it means human-controlled, then it would not be CNC, more like BNC: Brain Numerical Control.
#2 posted 05-23-2016 04:48 AM
Hint: Humor
It’s a carver, like CNC’s are, but it’s entirely human dependent.
