router difficult to move in base
Forum topic by leftcoaster posted 05-22-2016 11:25 AM 807 views 0 times favorited 2 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
233 posts in 1116 days
05-22-2016 11:25 AM
I have a Bosch 1617 and the Bosch bench top table. I undo the clamp and align the arrows to get the router into the base, twist and slide. It is VERY difficult to get it seated and yes, I am pressing the gross adjustment when I move it. It does move, but it’s a lot of work.
I don’t see any obvious obstructions. Should I use furniture wax? Is there an adjustment that would give me more play?
I also don’t see a lot of movement on bit height when I use the fine adjustment (also with the lever depressed and the clamp disengaged). So, something is not right but I am stumped as to what.
2 replies so far
View conifur's profile
conifur
955 posts in 1391 days
#1 posted 05-22-2016 12:18 PM
Try waxing it and/or loosen up the nut on the clamping bracket.
View Lifesaver2000's profile
Lifesaver2000
556 posts in 3352 days
#2 posted 05-22-2016 02:19 PM
I had the same thing happen with this router, and a cleaning and rubbing it with paraffin fixed it right up.
