Restoring a Ship's Binnacle and I need assistance
« back to Woodturning forum
Forum topic by kcroyals22 posted 05-21-2016 12:38 PM 910 views 0 times favorited 11 replies Add to Favorites Watch
View kcroyals22's profile
kcroyals22
3 posts in 868 days
05-21-2016 12:38 PM
I am trying to restore a small ship’s binnacle and am almost at completion. I am at a point beyond my skill level. I have a square base for it, but there is a transition piece of moulding that I will need. It is very similar to the moulding you see on round columns. Any one good at this task??
11 replies so far
View HerbC's profile (online now)
HerbC
1773 posts in 2914 days
#1 posted 05-21-2016 01:42 PM
Turn it with a lathe.
If you don’t have a lathe, find a friend who has one and get them to do it…
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View TheFridge's profile
TheFridge
9711 posts in 1541 days
#2 posted 05-21-2016 01:49 PM
Yep
Or it sounds like a good reason to buy one
View jbay's profile
jbay
2430 posts in 954 days
#3 posted 05-21-2016 02:18 PM
Looks like a disk with a routed edge.
Glue up a blank, cut it round, rout the edge.
If it’s a molding, cut out the center to make it a ring instead of a disk.
View Nubsnstubs's profile
Nubsnstubs
1305 posts in 1785 days
#4 posted 05-21-2016 02:21 PM
What’s the diameter? ........... Jerry (in Tucson)
View waho6o9's profile
waho6o9
8242 posts in 2632 days
#5 posted 05-21-2016 02:31 PM
http://microfence.com/circle-jigs-c-23.html?osCsid=1dac81e46a54ea11a9c7c9661dd4b62c
Good opportunity to increase your skill levels.
Practice on scraps and have fun.
kcroyals22
3 posts in 868 days
#6 posted 05-21-2016 03:06 PM
Nubsnstubs the diameter of the column is 11 1/2”
View BurlyBob's profile
BurlyBob
5651 posts in 2320 days
#7 posted 05-21-2016 04:27 PM
I’m thinking you need to contact “shipwright”. He’s probably the most knowledgeable boat guy here.
Nubsnstubs
#8 posted 05-21-2016 04:33 PM
What waho6o9 posted is ok if you’re rich. here’s what you do if you’re poor like me. Get a piece of 1/4” ply, mdf core sheet, or if you a few dollars to spend, a piece of 1/4” clear poly carbonate. Use the removed router plate and use it to mark and drill holes to fit the router base. Attach it to your router base, and find the center point. Mark out from there 5 3/4”. Get your piece of wood, find center, and screw the base to the wood with your bit retracted. Turn the router around the pice to see if you are on the 11 1/2” circle you drew earlier on. If it’s on the line, lower the bit with the router turned on, and do about a 1/4” deep cut. Check the diameter and if it’s ok, go ahead and finish with about 2-3 more passes.
If it’s too small, or too large, adjust by setting another hole near the first hole in the plate to compensate for the difference. Centering it doesn’t matter on the trammel you made. Have fun.
Is this a ring, or is it a round depression with a square base?............ Jerry (in Tucson)
View MrRon's profile
MrRon
4868 posts in 3298 days
#9 posted 05-21-2016 07:04 PM
Get a piece of hardwood, mount it on the lathe. Turn the profile, then make the inside cut. The “scrap” piece will be your ring.
View REO's profile
REO
928 posts in 2129 days
#10 posted 05-22-2016 01:20 AM
Nubs has a great economical one off solution!
View Leo Van Der Loo's profile
Leo Van Der Loo
45 posts in 813 days
#11 posted 05-24-2016 04:06 AM
That piece is not a ring on the one I rebuild, but a solid piece made out of two boards.
The square base on mine is about 17” and the round piece is about 16”, on top of that is a 12 sided (IIRC) piece where the outside of the body/column is screwed to.
The best way IMO is to get a couple of boards glued up and then sawn round, then turned on a lathe with the profile you would like.
-- Have fun and take care
