Oil based poly woes.
Forum topic by NateX posted 04-07-2010 07:59 PM 2055 views 0 times favorited 12 replies Add to Favorites Watch
View NateX's profile
NateX
98 posts in 2993 days
04-07-2010 07:59 PM
Topic tags/keywords: finishing
I never really used polyurethane until this new project. I built a book case and stained it with a water based dye stain, came out nicely. Then i tried to put on a top coat, on my 3rd try.
I have been having problems with the oil based poly top coat. No matter what I do I seem to get sags and runs. I walk away with a nice even, smooth coat and come back to runs and weird hanging sags, kinda looks like a curtain. I have already stripped and sanded this project twice because of finishing woes. This last time i thinned the poly with mineral spirits, about 5:1. It went on a little better and I certainly had more working time.
Any tips for oil based poly, or poly in general? Is it a good choice for this kind of project? How about armor seal from GF, the wood whisperer likes it. Is it a good choice for large vertical surfaces?
I have used a tung oil varnish blend over stain before and that worked well but was pricey. Trying new things sucks!
Thanks for any advice-
Nate
12 replies so far
16274 posts in 4214 days
#1 posted 04-07-2010 09:22 PM
Are you brushing it on? Brushing poly on vertical surfaces without getting runs can be difficult.
Use a wipe-on poly, or make your own by mixing it 50/50 with mineral spirits. Wipe it on with a rag. It will take several coats to build it up, but the coats go on fast and easy, and dry quickly.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3477 days
#2 posted 04-07-2010 10:50 PM
I agree with Charlie…I would give the wipe on poly a try…it works very well.
-- Wayne - Plymouth MN
View bayspt's profile
bayspt
292 posts in 3701 days
#3 posted 04-07-2010 11:14 PM
I also noticed you said you used water based stain and are using oil poly. I would generally not take this risk without a coat of shellac or something in-between. I’m sure if the stain is fully “cured” it is probably ok, but I just wouldn’t take the risk. Then again, I am no finishing guru so it might all be hog wash.
-- Jimmy, Oklahoma "It's a dog-eat-dog world, and I'm wearing milkbone underwear!"
NateX
#4 posted 04-08-2010 12:16 AM
The stain looks good, didn’t move on me with the oil. I’ll try knocking down the lumps with some steel wool and thinning out the poly a little more. Thanks for the tips!
NateX
#5 posted 04-08-2010 02:10 AM
You guys are awesome! thinning out the poly with mineral spirits by about a third and using a cloth made all the difference in my project!
pics soon.
THANKS!!!!!!!!
-Nate
#6 posted 04-08-2010 02:20 AM
Glad it worked out!
View CaptainSkully's profile
CaptainSkully
1597 posts in 3555 days
#7 posted 04-08-2010 03:03 AM
My father-in-law noticed that my alcohol-based shellac was messing with my alcohol-based aniline dye because they have the same solvent.
-- You can't control the wind, but you can trim your sails
teenagewoodworker
2727 posts in 3764 days
#8 posted 04-08-2010 03:13 AM
don’t thin the poly… that will cause it to run more. just leave it as is and make sure that you wipe it off well… poly is made to be a very very thin coat. its not thick at all. try a good quality varnish as well like seal a cell and arm r seal from general finishes. I don’t know what kind your using but the minwax stuff is horrible,.
27250 posts in 3818 days
#9 posted 04-08-2010 01:21 PM
Glad it worked out well for you Nate. I am a little late on getting into this discussion but using a wipe on poly is what I usually advise when I see questions like this. While poly can be applied as a concentrated product it requires practice to avoid sags and runs. Diluting it with mineral spirits to form a wiping product is a good way to avoid this problem. It will take more coats to “build” the finish since this is a diluted product. But it dries quickly and several coats can be applied in a very short time frame.
And it was a good idea to make your own. Wiping varnishes are commercially available but I just do not like paying a premium price for someone else to add mineral spirits to the poly or varnish.
NateX
#10 posted 04-08-2010 09:04 PM
The finish looks pretty good, but I want to make it better. I have heard of this paper bag trick, the one where you use a paper grocery bag as an abrasive to smooth the finish. Does this work on poly? Any considerations I should make with the cure time before I try this?
I used Varathane oil based poly, 0000 steel wool between coats. I do all my work outside and the breze blew some dust and pollen onto the finish so it’s a not glassy smooth. Darn breezy perfect spring afternoons!
Thanks again for the advice!
#11 posted 04-09-2010 02:20 AM
Nate, the paper bag should work on the poly as well. I have never tried it but it is simply an ultra fine abrasive material that should serve to help flatten the poly topcoat. To smooth out the poly I generally wait at least 3 days after the final coat to let it cure out and then I like to sand with 600 grit to remove any dust nibs and rough surfaces.
By the way here is a 15 part video series that takes the viewer through the individual steps from initial sanding to final polishing to get a classic glass smooth finish. It is a lot of work, certainly far more than I go through, but if you have not seen the series, and are interested in taking your finishing to this level, the series may be of interest to you.
View Ger21's profile
Ger21
1074 posts in 3127 days
#12 posted 04-09-2010 03:41 AM
Wet sand with mineral spirits to 600, then use 0000 steel wool, again lubricated with mineral spirits, and you’ll get a smoother than glass finish.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
