Glue
Forum topic by Harryn posted 05-19-2016 04:35 PM 736 views 0 times favorited 6 replies Add to Favorites Watch
View Harryn's profile
Harryn
65 posts in 2642 days
05-19-2016 04:35 PM
Is tite bond II stronger than tite bond III for indoor use?
View TJones's profile
TJones
8 posts in 936 days
#1 posted 05-19-2016 04:56 PM
Don’t know if it is any stronger per se….Titebond III’s biggest difference is it’s slightly longer open time
T.
-- Tony, Sullivan IL
View MrUnix's profile
MrUnix
6827 posts in 2252 days
#2 posted 05-19-2016 05:28 PM
TBIII is marginally stronger, but much more expensive. Here is a comparison chart of various glues from Fine Woodworking…
The glues tested:
The results:
Notice that normal PVA glue is rated as the best value and it’s strength is not that much less than TBIII (and probably about the same or better than TBI and TBII). It’s one advantage (TBIII) is water resistance. Here is the difference in strengths between the Titebonds:
The above was taken from:
How Strong Is Your Glue?
Differences Between Titebond Glues
PS: It should be noted that while not mentioned, epoxy is waterproof as well, and probably more so than TBIII.
View pintodeluxe's profile
pintodeluxe
5725 posts in 2867 days
#3 posted 05-19-2016 06:06 PM
I like the way TBII works and finishes better than TBIII. I usually have a mortise and tenon joint (pegged) that would hold together without glue, so absolute strength is less important to me than the realities of using the product.
TBIII can leave a dark glueline. This is okay for dark wood projects such as walnut, however for oak and other light colored hardwoods I select TBII.
View Jim Finn's profile
Jim Finn
2661 posts in 2975 days
#4 posted 05-19-2016 11:04 PM
I use Elmer’s white glue and it is stronger than the wood. Why would you want anything stronger?
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
View distrbd's profile
distrbd
2252 posts in 2500 days
#5 posted 05-20-2016 12:36 AM
For me TBIII all the way, I like everything about it,the color when it dries, the strength, long open time, one gallon lasts me a year or two,why mess with other stuff when there’s no need. right?
-- Ken from Ontario, Canada
View Woodknack's profile (online now)
Woodknack
12055 posts in 2434 days
#6 posted 05-20-2016 12:57 AM
It doesn’t matter
