I'm interested in using some metal dovetail keys and I'm trying to find out if there is anywhere I can buy them premade. I'm doing some molten aluminum dovetail keys that are poured directly onto the wood too, but it gives a different look than I want on some of my nicer pieces.
I'm honestly not sure. I could probably get them laser cut at my work, but it's a hassle. I might just get some strips of aluminum or brass and do them myself on the band saw and smooth it out. I was just hoping to get lucky on it first. I included a picture of one I have seen before. I think it could work out really well having a contrasting metal key just slightly proud of the slab. I have quite a few gorgeous walnut slabs that would look great with something like this.
I have some oak slabs that I want to try to solid pour on. I'm going to block off one side of the slab and then prepare the area just like normal, but then pour over the molten aluminum to fill the crack and the key hole. It will leave a little bit of charred area, but I think that will add to it.
As a long time metal worker (60 years) I can pretty much assure you that finding a triangular shaped strip of brass or any other metal for a dovetail key are nil. You are probably going to have to buy a strip of brass and file it to shape or use a belt sander. Lots of work I know, but unless you have access to a metal lathe or milling machine, those are your options.
Another thought. You may want to consider pewter. It has a relatively low melting point (446 °F +/- depending on the composition) that would pour into a joint. Looks very much like silver.
How thick do the keys need to be? I slowed down an 18" bandsaw with step pulleys and a jack shaft, and used a bimetal blade to cut shapes out of a bronze water tank (interesting project, but not relevant here). It worked very well. The tank walls were at least 1/8" thick. If you have to go much thicker, it could be tough. One problem is there will be a lot of heat buildup.
Why don't you make a mold and pour them yourself. Then cut the holes to match.
You could make it as tall as you need, to get as many as you need, then slice them to the thickness you want.
I just got a similar idea from that link. On the page side they showed some elongated S hooks. I think they would look good in the place of the bow tie for the same use. I always carve pieces out of wax and use plaster to make a mold for parts like this.
You can use a router and an inlay cutting set. Cut the desired shape of your key in a panel of masonite, this will be your template. Position the template on your wood slab where you desire the key to be located. Attach the rub collar to the router inlay guide. Cut the recess in the wood slab (say 1/4" deep). Take the same masonite template to your brass stock and without the rub collar, route the shape of you key (slightly deeper then 1/4"). Now take the brass stock with the outline of your key cut into the surface and resaw it on your bandsaw (blade was mentioned above). You'll have a 1/4" thick brass butterfly key that fits the recess exactly. Add some epoxy to the recess in the slab, insert the butterfly, tap it down and sand flush if necessary.
You could use other metals like cerrosafe. These are alloys that melt at low temperatures (220 degrees and up). Looks like aluminum.
Be aware that they may contain elements that can be toxic (lead, indium, etc.)
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
