Router sled discovery ***Thread Fixed***
Forum topic by ajthomas5009 posted 05-18-2016 07:07 PM 1798 views 1 time favorited 27 replies Add to Favorites Watch
View ajthomas5009's profile
ajthomas5009
296 posts in 1734 days
05-18-2016 07:07 PM
Topic tags/keywords: jig tip resource router milling joining finishing
Today I was surfacing a batch of five end grain cutting boards with my router sled. This is something I’ve done about 20 times. So I’m not a rookie to the procedure but I wouldn’t call myself a leading expert.
My usual results with the router sled is a pretty damn flat surface, smooth but with some minor tearout and and bit ridges. None of this is even an issue on face or edge grain. But with end grain those imperfections mean a minimum of an hour of rough orbital sanding followed by another hour of fine sanding through the grits. When doing 5 boards that 10hrs of vibrating your arm off and one would be lucky if they could tolerate it enough to finish it in 16hrs with breaks.
So I said to myself there has to be a better way without a drum/belt sander. Well I played around with my router sled and hit the jackpot!!!
First I tightened up the slop in the router carriage. It was only about 1/16” to start but making it a friction fit eliminated irregularities in the surface caused by vibration/movement and the occasional climb cut.
The rest had to do with technique. Keep the speed moderately slow going back and forth in the same spot before moving on. Also it helps to take 2 final passes after everything is flat. First pass take off 1/32” then the 2nd do 1/64”. If there is still a decent amount of tearout after the 1/32” pass do another a 32nd lower before moving on.
This process took about 10mins longer but it cut out hours of annoying sanding.
The pics are are of the boards. In one of the pics you can see a close up of some minor tearout I left. The surfaces look polished almost.
Andrew
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
27 replies so far
View PhillipRCW's profile
PhillipRCW
506 posts in 1381 days
#1 posted 05-18-2016 08:56 PM
Are you going to share your jackpot finding?
-- Phillip- Measure twice, cut onc.... Hey look, it's rustic.
ajthomas5009
#2 posted 05-18-2016 09:21 PM
If your referring to pics that is possible
View JoeinGa's profile
JoeinGa
7739 posts in 2123 days
#3 posted 05-18-2016 09:23 PM
Yes, post some pics please
View putty's profile
putty
1208 posts in 1723 days
#4 posted 05-18-2016 09:38 PM
so…finish the story!
-- Putty
View Woodchuck2010's profile
Woodchuck2010
716 posts in 975 days
#5 posted 05-18-2016 10:19 PM
Well good for you.
-- Chuck, Michigan,
View conifur's profile
conifur
955 posts in 1268 days
#6 posted 05-18-2016 10:37 PM
Another dumb thread, Say What????
View nkawtg's profile
nkawtg
280 posts in 1368 days
#7 posted 05-18-2016 10:45 PM
Well I’ll bite, what was your solution?
View Redoak49's profile
Redoak49
3450 posts in 2105 days
#8 posted 05-18-2016 10:48 PM
Duh….
View vskgaming's profile
vskgaming
83 posts in 1731 days
#9 posted 05-18-2016 10:51 PM
BAZINGA!!!
-- VSKGAMING
ajthomas5009
#10 posted 05-18-2016 11:14 PM
What the heck. There was suppose to be another paragraph but it’s missing. I’ll fix it later tonight. That explain the asinine responses lmao
Redoak49
#11 posted 05-19-2016 12:50 AM
I think the right word is ”appropriate” responses given the actual post
View Woodknack's profile
Woodknack
12331 posts in 2497 days
#12 posted 05-19-2016 01:53 AM
Blue balls.
View oldnovice's profile
oldnovice
7120 posts in 3484 days
#13 posted 05-19-2016 04:53 AM
In my opinion, unless you see a potential market for your “breakthrough”, it would be nice to share with your fellow woodworkers so they can use it or at least make decent comments.
View AlaskaGuy's profile
AlaskaGuy
4354 posts in 2426 days
#14 posted 05-19-2016 05:50 AM
Some people just do like to tell you where they caught all those fish. :)
ajthomas5009
#15 posted 05-19-2016 07:13 PM
Again sorry about the confusion with the half finished post. It wasn’t intentional. I just figured I’d share my doscovery as a tip to others. Many people that use a router to surface complain of tearout/machine marks. So I figure the info would come in handy to some.
