| Forum topic by Greg Wurst | posted 349 days ago | 401 views | 0 times favorited | 10 replies | ![]() |
349 days ago |
I’m trying to duplicate the joinery in an entertainment center I have, and they have used a rather unique profile for the door rail and stile construction:
I can probably recreate it manually using multiple bits, but it would be much easier to find a couple bits that would make the entire profile at once. Has anyone seem something similar? Thanks, Greg |
349 days ago |
Gwirst. You can always get a custom build bit but it is not cheap. They probably used a shaper and stacked cutters to make that profile. This is possible (and common) on shapers but not on routers. Shapers have an axle on which you can mount a stack of profiles. The only option you have in a small shop is to reproduce the profile with multiple bits, I think. Alin -- -- Alin Dobra, Gainesville, Florida |
349 days ago |
I support Alin’s comments. It does not look like a very difficult profile to duplicate if you have to do it manually. -- Todd A. Clippinger, Montana, http://amcraftsman.com |
349 days ago |
I’d use a 3/16” roundover and a rabbet bit to cut the bottom cut. Using a bearing bit on each of the two bits should make it all line up fine. And no I’ve not seen any bit like it. You might be able to modify this bit with putting a rabbet bit on the top. It only seems to be available in 1/4, 3/8” profile, -- Karson Southern Delaware karson_morrison@bigfoot.com |
349 days ago |
He will have to have the positive and the negative of the profile to get the to pieces to mate. -- Todd A. Clippinger, Montana, http://amcraftsman.com |
349 days ago |
Do it in 2 passes, one round over and one rabbit -- Thos. Angle, Owyhee Design, Oregon |
349 days ago |
I don’t know why I didn’t think of it, but it probably was done on a shaper. I used to have one but never used it and sold it. It looks like I’m stuck using a combination of roundover, cove, and rabbit bits to reproduce the profile. I’ll have to experiment on some scrap, but my main concern is going to be getting the rails and stiles to match perfectly. If I can get the scrap pieces to mesh I can use them to setup the bits for the actual pieces. I wondered why they used a non-standard profile; but since they used a shaper it was cheap to use standard stacked shaper bits to create the desired profile without having to use relatively expensive panel router bits. |
349 days ago |
I didn’t realize that the cove on the other side was part of it. You can do this. You might have to buy a router bit that matches either the round over or the cove but the set up shouldn’t be any more trouble than a stick and cope set. One tip that you probably already know is to cut all the parts with the same profile at once. think of it as a cope and stick setup and cut the cope first. Then match the try sticks to the cope to cut the mating part. -- Thos. Angle, Owyhee Design, Oregon |
343 days ago |
Well, I did a quick and dirty proof of concept setup using some scrap MDF I had lying-around and it looks like it will work. I didn’t have a cove bit that even came close to a 1/2” overlay so I had to reduce the lip section to 1/4”, but otherwise it looks like it will work fine and is close enough to the original nobody is going to really notice.
343 days ago |
Very good -- Thos. Angle, Owyhee Design, Oregon |
343 days ago |
nice job, I knew you could do it. -- bryano |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1337 |
| Become a sponsor |
1778 |
| Become a sponsor |
123 |
| Become a sponsor |
371 |
| Become a sponsor |
108 |
| Become a sponsor |
Woodworking Trade & Swap
251 |
| Become a sponsor |
Coffee Lounge
1004 |
| Become a sponsor |
LumberJocks.com Site Feedback
284 |
