PCB270TS Lift Issue
Forum topic by WhoIsJohnGalt posted 05-18-2016 04:28 PM 509 views 0 times favorited 1 reply Add to Favorites Watch
View WhoIsJohnGalt's profile
WhoIsJohnGalt
3 posts in 1282 days
05-18-2016 04:28 PM
Topic tags/keywords: pcb270ts
I have had the PCB270TS for nearly four years (maybe more) and generally it has been good for me. I have one issue that I cannot figure out a solution for. I find that the lift mechanism accumulates sawdust on the worm drive (not sure if it is from the worm gear or screw shaft). Anyway, this accumulation makes it impossible for me to fully lower the blade. I am one who likes to lower the blade below the table surface and then place a cover over the cast iron to prevent rust and accidents (damage to the blade or minor cuts to my fingers or projects).
Has anyone else noticed this and found away to prevent the accumulation of the sawdust on the lift mechanism? It is a real PITA to clean out because I basically have to crawl under the saw (or tip it all the way over) to access the lift.
1 reply so far
View FancyShoes's profile
FancyShoes
550 posts in 1332 days
#1 posted 05-26-2016 03:28 AM
I think there is a wax or a spray can that helps prevent the build up. Maybe you can run a air hose to the underside of the tablesaw pointed at the worm drives like many orher machines have to keep the area clean. As well as some good dust extraction, saw dust likes to stick to oil and grease.
Good luck.
