Metal Logo for Projects?
Forum topic by GunsOfNavarone posted 05-18-2016 02:47 PM 3088 views 0 times favorited 15 replies Add to Favorites Watch
View GunsOfNavarone's profile
GunsOfNavarone
30 posts in 1014 days
05-18-2016 02:47 PM
Topic tags/keywords: label logo
I did a fair bit of searching, and I couldn’t find this specific topic. I’ve been searching for a place to get small embossed metal logos to label my woodworking projects (like the ones the MTM Wood guy uses on his cutting boards as shown attached). I found some questionable websites that appeared to be coming from Asia. I’d prefer for the products to be made in USA, but I would buy from Asia if it was a reliable site.
I’ve got a buddy designing a logo for me, and I’m trying to figure out if I can use the metal logos and how much they’d cost. It seems that a lot of people here use branding or ink transfer to label projects. Does anyone use these metal logos for personal projects? Where do you get them?
Thanks!
EDIT: Sorry for the enormous image, I don’t know how to resize! That image is not mine, I found it via google.
15 replies so far
View AandCstyle's profile
AandCstyle
3178 posts in 2457 days
#1 posted 05-18-2016 10:00 PM
Guns, you can try searching for custom metal coins or medallions. They can be quite reasonable depending on the quantity you choose to purchase. FWIW
-- Art
View jeffswildwood's profile
jeffswildwood
3599 posts in 2177 days
#2 posted 05-18-2016 11:56 PM
There are many sites sell military challenge coins to your design. I’m quite sure they could add the screw holes if they can make those intricate designs. Worth a try. No charge for asking. Here is a couple I found but there are many many more.
https://www.challengecoin.com/
http://www.signaturecoins.com/
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View Redoak49's profile
Redoak49
3663 posts in 2188 days
#3 posted 05-19-2016 12:01 AM
Another option might be to have someone with a CNC cut them out of wood or plastic and then finish them.
View oldwood's profile
oldwood
155 posts in 1444 days
#4 posted 05-19-2016 01:57 AM
The picture is of a cast logo plate, not embossed. Quite a difference in price I would think.
GunsOfNavarone
#5 posted 05-19-2016 02:13 AM
Thanks everybody. I don’t know what the correct terminology is, and I’m not sure if it matters to me whether it’s embossed vs cast since I don’t even know the difference. I found a local place that quoted me about $3-$4 per piece depending on size and quantity, which is more than I’m willing to spend right now given the minimum requirements of 200. Printed was significantly cheaper at $2 but I’d worry about it holding up as well without scratching. I’ll look into the medal/coin option as that sounds promising. I also found some Chinese vendors on alibaba.com that were under a dollar per piece, some of which had good reviews. I appreciate all the help!
MrUnix
7043 posts in 2399 days
#6 posted 05-19-2016 02:22 AM
If you need a large quantity of them, it might be cheaper in the long run to get a set of engraved plates made and use them with a press to emboss (stamp) your own. You can get blank plates in bulk pretty cheap… any local company that deals in making trophies and awards should be able to steer you in the right direction.
View mrg's profile
mrg
837 posts in 3199 days
#7 posted 05-19-2016 02:33 AM
Try a print shop that deals with promotional materials. The company I used back when I was managing a shop was Big 10 industries if I remember correctly. They did tags, cups, pins etc. A trophy shop may even be able to engrave the logos for you on the brass tags or point you in the right direction.
-- mrg
View Cooler's profile
Cooler
299 posts in 1043 days
#8 posted 05-19-2016 01:31 PM
Here’s one: http://www.imageworksmfg.com/Nameplates/metal.html
Here’s a google search and more: https://www.google.com/search?q=nameplate+manufacturers&rlz=1C1RXDB_enUS585US585&espv=2&biw=1366&bih=667&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj59ezxnubMAhVIXD4KHS9CAToQ_AUIBygC
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
View builtinbkyn's profile
builtinbkyn
2653 posts in 1140 days
#9 posted 05-19-2016 01:42 PM
This place seems to do what you’re looking for.
Custom Medallions
-- Bill, Yo!......in Brooklyn & Steel City :)
GunsOfNavarone
#10 posted 05-19-2016 03:46 PM
Thanks again everybody. I found a couple local places that are providing quotes. I was hoping someone here had experience in ordering something like this, but it doesn’t look like that’s the case. I’m checking with the “Logotags” company to see if I can get a price from them, and I might reach out to some of the alibaba companies to see if they seem legit. Thanks for taking the time to respond everyone!
Cooler
#11 posted 05-19-2016 03:55 PM
A less costly but still attractive method is to emboss foil labels. A label embosser from Staples is under $50.00. The blank gold foil labels are very cheap.
But get the labels that require water to glue it on and not the self-adhesive ones. The extra thickness of the release paper makes for a poor impression on the foil.
http://stampworx2000.biz/yahoo_site_admin/assets/images/SealImp2.4281702.jpg
View scott6118's profile
scott6118
1 post in 537 days
#12 posted 06-23-2017 03:18 PM
I am a woodworker and I also work for LogoTags.
We make a ton of different name plate styles for woodworking.
I actually use it on my own stuff all the time.
LogoTags-Custom Metal Tags
View Madmark2's profile
Madmark2
405 posts in 788 days
#13 posted 06-23-2017 07:48 PM
MicroMark sells low temp (~160°F) metal casting and mold making tools for small items.
M
View JAnderson's profile
JAnderson
1 post in 413 days
#14 posted 10-26-2017 02:49 AM
Nice piece! I just bought coins for my local VFW from http://customchallengecoins.net/ the coins came out beautiful, a lot of attention to details, and the staff was great to work with, very fast to respond. They also have a sister site which I believe might help you, it’s http://www.lapelpins.net
View siconlamirada's profile
siconlamirada
1 post in 332 days
#15 posted 01-14-2018 10:21 PM
These guys did a pretty awesome job for me: https://embleholics.com/. I see that you already have a guy getting this thing designed for you but their designers actually did a great work and took like 2-3 revisions until they came out perfect.
