Dust collection advice?
Forum topic by Zac80 posted 05-18-2016 03:59 AM 1525 views 0 times favorited 26 replies Add to Favorites Watch
View Zac80's profile
Zac80
17 posts in 791 days
05-18-2016 03:59 AM
Topic tags/keywords: dust collection
I have a small 1 car garage shop. Using mostly power hand tools and radial arm and table saw. What type of system is required for that space and tool usage. Any advice or product in particular? Thanks, much appreciated.
26 replies so far
View MadMark's profile
MadMark
979 posts in 1505 days
#1 posted 05-18-2016 04:53 AM
At that level a shop vac is all you need.
M
View Ger21's profile
Ger21
1075 posts in 3183 days
#2 posted 05-18-2016 12:16 PM
I’d get a 2HP Harbor Freight.
A ShopVac is useless with a table saw.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
5013 posts in 2545 days
#3 posted 05-18-2016 12:21 PM
- Ger21
Pretty much true with an RAS as well.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2422 days
#4 posted 05-18-2016 01:03 PM
I work in a 2-car garage, but a large portion of it is taken up by storage, so I know where you’re coming from. I had the shop vac and dust deputy for a couple years, and it did well, but still left a lot to be desired, especially from the table saw. I had a RAS for a year, and got rid of it. I couldn’t justify losing that much space for cuts that could be done on the table saw. If I had a larger shop, I’d have kept it. So, something to consider. In that same space I was able to park my planer and jointer.
I recently upgraded tp a 3HP DC with a trash can separator (I got a good deal on it, it’s more than I need). I stuck it n the corner and ran the hose along the ceiling, with a single drop in the center of the shop next to a support pole. Since all of the tools are mobile, and stored against the walls, they get wheeled to the hose when in use.
I picked up one of the grizzly air filters about a month or two ago, and hung it from the ceiling. I think it was on sale for around $110. That made a very noticeable difference. The table saw, even with the DC, would still kick up a lot of very fine dust. Before, that dust would hang around the entire time I was in the garage. Now, I can see the dust getting sucked into the air filter, and within a few minutes, its gone.
I still use the shop vac for tools like my random orbit sander and my handheld router.
So, a couple things to consider :
- A DC, with a separator, is going to take up some space. Probably about the same space as that RAS you have. Do you use the RAS much? They have their benefits, but in a one car garage, I don’t feel the benefits outweigh the valuable floor space they consume.
- The shop vac with the dust deputy works good for smaller tools, not well at all for the table saw, and mediocre for a planer. Better than nothing, and if you’re stuck with a shop vac, the dust deputy is a great way to keep it from clogging filters.
- A DC generates a different noise than the shop vac. In my house, the kids’ bedrooms are located over the garage. So, I can run the shop vac while they’re sleeping, but not the dust collector. Both are noisy, but the dust collector sound carries through the house much more, whereas the shop vac noise gets killed pretty well by the insulation around the garage. So, if noise is a consideration, there’s that.
- Even with the DC, I still wear my respirator when I’m using the table saw or the router table. It’s a 3M with the replaceable cartridges, I have different cartridges for dust and finishing. Definitely worth the money (I think it was around $30).
- If you go the DC route, verify that your electrical can support it (110 vs 220, how much load is on the circuit, etc). Our garage does nto have 220, so when I run the DC, I have a short extension cord that can plug into the dryer vent, which si located just inside the garage wall.
View Notw's profile
Notw
654 posts in 1805 days
#5 posted 05-18-2016 01:56 PM
I agree with Ed, I have a 1 car garage shop and use a 2HP HF dust collector with a Thein top hat separator. I used PVC to pipe everything overhead because I didn’t want the hose to be a tripping hazard. I have a blog about what I did if you’d like to check it out.
View jesinfla's profile
jesinfla
275 posts in 1190 days
#6 posted 05-18-2016 03:21 PM
I have a 2 car garage and only use 1 side of it – the tools I use are some battery drills, a table saw, a miter saw and now a drill press.
I tried to cut corners in the beginning by using my Rigid shop vac – it worked but was a real pain because I had to keep emptying the bin and cleaning the filter – this really sucked.
I found coupons for the harbor freight 2 HP dust collector and paid $159 for it – I now can run dust collection not only to the tools I currently have but can expand as my usage grows.
In addition, I have hoses to reach all over the garage to every work station I create
The wife also uses it to vacuum the cars LOL
-- They said I could be anything... So I became Sarcastic! They also said making drawers is easy... I think they lied :(
View rwe2156's profile
rwe2156
2999 posts in 1533 days
#7 posted 05-18-2016 03:46 PM
If the machines are fairly close together, a portable 1 1/2 unit with 4-6” flex hose will work fine for what you’re doing.
A shop vac is the best way to go for routers, miter saws, sanders, etc.
View Richard H's profile
Richard H
489 posts in 1733 days
#8 posted 05-18-2016 03:47 PM
I work in a 2 car garage and tend to bring my tools to the dust collector instead of the other way around. I have a oldish Delta DC similar in design to the HF which has a single 20’ collapsable hose attached to it next to the open spot where I wheel all my tools to. The hose is also long enough to hook to the tablesaw. I also have a shop vac that I use for connecting to hand tools. I don’t feel like I have the room to work at my stationary tools where they are stored but some of that is also very limited power as well so when I want to use something I wheel the tool over to the open working spot, hook it up to the DC and use it from there. I do a lot of swapping back and forth especially between the jointer/planner and I would love to have fixed spots for everything so I didn’t have to and have the DC ducted to them (would upgrade to a cyclone if I did that) but given the space/power constraints I work with what I have. I at one time had piping around my shop but when I moved I never reconnected it as I found I only ever used one or two of the drops anyways because I didn’t leave enough space around my stationary tools to work at without moving the tool out of storage.
Handheld power tools don’t work very well connected to a full sized DC and stationary power tools don’t work very well connected to a shop vac. You really need both but if you can only swing one of them I would probably go with the shop vac and clean up manually. A DC is a specialized tool that serves one purpose where a shop vac while not ideal for gathering dust from larger tools can be used for a number of other clean up jobs as well. However when you finally get a planer you will want to consider how you are going to handle dust collection on that thing as they don’t work well without a DC (unless they have it built in) and a shop vac is way to small to deal with it. A planer is the one tool in my shop that I won’t every run without the DC hooked up to it. The others I can get by cleaning up after with the shop vac if I want.
View ScottM's profile
ScottM
658 posts in 2199 days
#9 posted 05-18-2016 06:02 PM
Same setup here. I don’t have any fixed position tools. Everything is on wheels; table saw router table, band saw, planer, oscillating sander, etc. I just use a shop vac with the Dust Deputy cyclone on the cart at Woodsmith. Works fine for me. Yes, there is some cleanup but you’ll never get away from that.
Zac80
#10 posted 05-18-2016 07:31 PM
Rockler has a small DC UNIT for 200 that can hang from the wall, which I thought would be good for space saving. Any opinions on that one?
View 01ntrain's profile
01ntrain
255 posts in 1122 days
#11 posted 05-18-2016 08:46 PM
- Zac80
If it’s the one I’m thinking about you have to have the retractable hose system to work with it? Which isn’t cheap, either. The bag is not a fine dust collector, either.(i.e. will not filter fine-dust) For $200 you can get the HFT DC and have money left over for pipe runs and whatnot.
Don’t let space(or lack of it) be the determining factor for your health.
There are lot’s of ideas out there to turn that HF DC into an adequate machine with a somewhat small footprint. Honestly, in my small shop, if I didn’t already have a Jet, I would buy one in a heartbeat.
View Rentvent's profile
Rentvent
151 posts in 901 days
#12 posted 05-19-2016 12:17 AM
+1 vote for the HF DC.
Here’s my favorite modification:
http://lumberjocks.com/projects/106615
It also proves that if you add a good separator, you don’t need the big clear plastic baggie and can use the space for something else.
View MinnesotaSteve's profile
MinnesotaSteve
52 posts in 943 days
#13 posted 05-20-2016 03:41 PM
If it s the one I m thinking about you have to have the retractable hose system to work with it? Which isn t cheap, either. The bag is not a fine dust collector, either.(i.e. will not filter fine-dust) For $200 you can get the HFT DC and have money left over for pipe runs and whatnot.
Don t let space(or lack of it) be the determining factor for your health.
There are lot s of ideas out there to turn that HF DC into an adequate machine with a somewhat small footprint. Honestly, in my small shop, if I didn t already have a Jet, I would buy one in a heartbeat.
I have the Rockler unit. There’s no reason why you have to use the retractable hose with it… you can hook it up with pipe just like any other dust collector. But the retractable hose is an option if it works with your space. Really if you look at any of these, they all have this core motor and impeller and the differences is where and how they direct the flow of air… into a filter bag, or a two bag, or cyclone, filter canister, etc. but the core of moving the air is pretty much the same design.
It’s well made, and I didn’t find it to be very loud, it’s certainly quieter than a shopvac. It’s about as loud as my Jet AFS-1000B on it’s medium setting.
View Mainiac Matt 's profile
Mainiac Matt
8160 posts in 2380 days
#14 posted 05-20-2016 03:54 PM
For that size shop and hobby use, any 1.5 to 2 HP single stage DC will do you just fine.
Filters are better than bags, but if there’s plenty of fresh air exchanged in the shop (overhead doors open) a bag system will be fine.
You can go as far (and spend as much $) with this as you want, but a single stage is all you really need.
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
View Woodknack's profile
Woodknack
12025 posts in 2432 days
#15 posted 05-20-2016 05:26 PM
I have a Delta 1hp. Not enough power for running a bunch of lines but more than enough for one machine at a time, which is fine for me as I have a small shop. Having it is 1,000,020X better than no dust collector.
