Replacement Arbor Wrench for Jet JWTS-10CW
Forum topic by benchandler posted 05-18-2016 03:59 AM 1330 views 0 times favorited 10 replies Add to Favorites Watch
View benchandler's profile
benchandler
3 posts in 735 days
05-18-2016 03:59 AM
Topic tags/keywords: tablesaw jet jwts-10cw arbor wrench newb
Hello good people. I’m new to the forum (short time lurker) and hobby (obsession?) but needed a little help.
I picked up a used Jet JWTS-10CW from CL and am in the process of cleaning, setting up, adjusting, upgrading etc.
Unfortunately it did not come with the arbor wrench and I am having trouble finding a replacement.
My research leads me to believe that I need Jet Part # 200252, but it is discontinued.
Sears Parts Direct says that Jet Part # JTAS10-170 is a suitable replacement but I don’t know if I can trust that.
Is there anyone here who has a saw from the same period/family that can get the dimensions of their arbor wrench so I know what to look for?
Amazon has Thin Wrench sets (Made by “Grip”, they look like cheap garbage) but I don’t really want to spend $40 + S&H on both the SAE and Metric sets when I only need one wrench, and the handles look a little short for the purpose.
Many thanks in advance.
-- When the going gets weird, the weird turn pro. - HST
10 replies so far
View MrUnix's profile
MrUnix
6704 posts in 2194 days
#1 posted 05-18-2016 04:05 AM
I believe the original wrench had a 23mm on one end and a 27mm on the other. Any normal box end wrench should work to remove/install the arbor nut though – no need to get an OEM stamped piece of metal. You only need the one that fits on the arbor nut.
runswithscissors
2750 posts in 2021 days
#2 posted 05-18-2016 05:01 AM
Go to your local thrift store or pawn shop. Buy a wrench that will fit (probably $.50 to $1.00). Grind it thin enough to fit where you need to insert it. Easy peasy.
4984 posts in 2489 days
#3 posted 05-18-2016 10:42 AM
This may be a quicker/cheaper/easier approach. Park bicycle wrenches (metric sizes only) are not only very thin, they are very high quality and easily obtained. A good bike shop will have them, or go the ‘zon. If the above info about 23mm and 27Mm is correct should be a piece of cake to get usable wrenches quick. As a side comment, how in the hell does so many arbor wrenches get lost?
View JoeinGa's profile
JoeinGa
7736 posts in 2002 days
#4 posted 05-18-2016 11:22 AM
How “handy” are you? I made my own. No welding necessary, just a hunk of steel, a 4.5” grinder and a few files. Paint if you like. Spent about a day on it.,,, see it here.
http://lumberjocks.com/topics/150730
benchandler
3 posts in 735 days
#5 posted 05-18-2016 03:37 PM
You guys are awesome.
I currently do not have a grinder, but am always looking for an excuse to get new tools. I’d be more inclined to grind down an existing 23mm & 27mm than to build my own, but that’s just on account of needing to pare down the list of projects as opposed to adding to it. I’ll also keep my eyes out for used cone wrenches.
MrUnix
#6 posted 05-18-2016 06:15 PM
There shouldn’t be any need to grind one down… unless you are looking for something that fits the arbor (not the arbor nut), which isn’t really needed. Any wrench (even an adjustable) should work just fine as long as you hold the blade in position with a piece of scrap wood, negating the need to hold the arbor in position.
benchandler
3 posts in 735 days
#7 posted 05-18-2016 08:09 PM
I’m happy using a standard box wrench on the nut but would prefer to have a saw specific slim wrench to hold the arbor itself in lieu of using the scrap wood method when changing it out. Thanks again to all of you. I’ll be sure to post pics once it’s all set up.
View knotscott's profile
knotscott
8008 posts in 3371 days
#8 posted 05-18-2016 08:51 PM
I’d be surprised if a wrench from several other similar saws doesn’t fit….Grizzly, GI, PM, Shop Fox, Bridgewood, King, to name a few.
View dogmir's profile
dogmir
25 posts in 1968 days
#9 posted 05-19-2016 01:37 PM
I was missing mine but found a generic one that fit at my local restore for $1. I found one for you $8.40.
Wrench Link
View MrRon's profile
MrRon
4764 posts in 3239 days
#10 posted 05-19-2016 04:51 PM
Don’t forget, the nut does not have to be torque-tight. Over-tightening the nut can distort the blade. Usually finger tight and then an 1/8 to 1/4 turn more is all that is needed.
