Drawer joinery question.
« back to Joinery forum
Forum topic by Griffin_SC posted 05-17-2016 08:27 PM 668 views 0 times favorited 6 replies Add to Favorites Watch
View Griffin_SC's profile
Griffin_SC
17 posts in 671 days
05-17-2016 08:27 PM
I’ve gotten to the point of building my drawers finally. My original plan was for Poplar drawer boxes with a Oak face. Boxes would be built with a lap joint in the corners with a couple of pocket screws inside where they can’t be seen. Since then though I’m got access to a Dovetail jig that can do half-Blind joints and I’m thinking about going that direction. I have a couple questions though.
1. If I go with dovetails should I still use a separate face or pull it all together into one drawer with the face installed in with it.
2. If I do with a 1 piece drawer how should I completed the finish. I wasn’t planning on staining the poplar box. But I do need to stain the face of tails of the face. Do you stain/dye the face then glue it up? How well with the glue hold like that?
View DrDirt's profile
DrDirt
4418 posts in 3612 days
#1 posted 05-17-2016 08:52 PM
If you want ‘white (ish) drawers with a stained face… then do option 1, not a single piece front.
Also the separate front allows you some adjustment of the drawer front to set the gaps around the drawer.
If it is important to do the 1 piece method, suppose, you can always stain your drawer front BEFORE you assemble the drawer, just keep the stain out of the dovetail pockets. then put drops of glue in each half blind pocket, swish with a small brush and assemble the stained drawer.
View Redoak49's profile
Redoak49
3003 posts in 1859 days
#2 posted 05-17-2016 09:59 PM
DrDirt is correct with good advice. Personally, I like to make the boxes separately from the fronts as it makes finishing easier and alignment better.
Most times I pre finish my drawer sides and bottom. I then cut the dovetails and put them together. It makes finishing much easier.
View bruc101's profile
bruc101
1197 posts in 3412 days
#3 posted 05-18-2016 12:45 AM
Sho am glad to hear you’re going to use dovetails and not pocket screws to build those drawers with.
-- Bruce Free Plans http://plans.sawmillvalley.org
View rwe2156's profile
rwe2156
2749 posts in 1351 days
#4 posted 05-18-2016 12:04 PM
Sho am glad to hear you re going to use dovetails and not pocket screws to build those drawers with.
- bruc101
Griffin_SC
#5 posted 05-30-2016 03:49 AM
Will it look odd that my drawer box and face are the same size? Both pieces are going to be cut from 1×8.
View pintodeluxe's profile
pintodeluxe
5544 posts in 2683 days
#6 posted 05-30-2016 05:11 PM
I would go with the half-blind dovetails. To my way of thinking the decision of integral front vs. applied front is a matter of which type of drawer slides you select. With wood side mounted slides, I like to use an integral front. Undermount or side mount slides usually require 1/2” gaps between the drawer box and cabinet , so applied fronts work well to cover the gap.
As far as the finish, just stain the fronts before assembly. Keep the stain off of the glued area and you will be fine.
