| Forum topic by dalec | posted 1991 days ago | 437 views | 0 times favorited | 6 replies | ![]() |
1991 days ago |
Hi, I am about to start late on some Christmas presents. I have a couple of maple boards. They are 4/4 and 5/4. I plan to make one box and would like to make the box sides between 1/4” to 3/8” thick. The boards are 5-6” wide. I don’t have a band saw. So the alternatives as I see them are: resaw using my table saw or cutting the boards into 1/4 or 3/8” strips and gluing to get to suffiicently wide board to make the box sides. Did I miss any alternative or is there another way to go? Thanks Dalec |
#1 posted 1991 days ago |
The table saw should resaw those for you. Might want to take a few passes raising the blade each time depending on how good a blade and how much horsepower ya got. -- "The way to make a small fortune in woodworking- start with a large one" |
#2 posted 1991 days ago |
If you don’t have a cabinet shop in your area, you can cut as far as you can from both sides, then finish with a hand saw and clean it up with a planer, drum sander, or hand planes. Just another option. -- You can discover more about a person in an hour of play than in a year of conversation. (Plato) |
#3 posted 1991 days ago |
Thanks miles125, F.Luna and Tom(mot) I raised my TS blade to the highest setting, measured and came up very near 3”. Based on that measurement, I should be able to or come very close to resawing 6” boards. So it looks like I can take several passes til I get to the saw blade height and then flip the board to complete the resaw process. I will double check to be sure my blade is 90 degrees to the the table before I start this process. Any other suggestions on resaw on my TS? If it goes poorly, I will head off to the nearest cabinet shop. Dalec |
#4 posted 1991 days ago |
Well those seem to be your options. If you are going to do this often, I’d recommend a bandsaw as your next big purchase. Today I used my bandsaw with resaw blade to rip a 2 3/8” X 10” X 36” piece of cherry into four legs. I was concerned about the boards twisting and binding in the saw blade. (It didn’t happen, they cut perfectly straight) Ripped 3 – 2” X 9” X 20” long white pine in two 4.5” boards and then resawed them into 5/8” thick boards and jointed and planed it to 1/2 ” thick boards for a ship-lap back in a bedroom side lamp stand. My bandsaw is as important as my table saw to me. -- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware karson_morrison@bigfoot.com † |
#5 posted 1991 days ago |
I support the guys comments about taking several passes, and finish with a hand saw if necessary. Sounds like a perfect opportunity to plead your case for a new bandsaw. -- Todd A. Clippinger, Montana, http://americancraftsmanworkshop.com |
#6 posted 1991 days ago |
Thanks Karson and Todd for your thoughts on my little issue. I am in the middle of finishing some trim pieces for a friend, so can’t make saw dust for a few days. Once I am done with the finishing work, I will resaw the boards. I am just getting into woodworking. I agree it would be nice to have a band saw. It isn’t in the cards or the budget right now and then its an issue of finding room in our crowded garage. Now I am seeing the value of a band saw. I could also use a jointer. If I thought for minute, I could come up with a list of things I need. In any event, I may be coming back with a request for band saw recommendations sometime in the future. As a side note: One of the boards I have is figured maple. Not having any experience with this what may be a dumb question. If I ripped figured maple board into 1/4” or 3/8 strips to glue into a board 1/4” or 3/8” thick, would be figured maple show on the opposite axis? Dalec |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3551 |
15789 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6161 |
