Stabilizing thin planks
Forum topic by crazypete posted 05-17-2016 01:53 AM 673 views 0 times favorited 2 replies Add to Favorites Watch
View crazypete's profile
2 posts in 672 days
05-17-2016 01:53 AM
Hello Lumberjocks….
I wasn’t sure where to post this, so I hope this is ok.
I’m attempting to resin stabilize 1/4” planks of various wood species. Stabilizing hasn’t been a problem, but my planks are cupping in the oven, or shorty after being removed from the oven. Both 1/4 and flat sawn cuts are cupping. Clamping while curing hasn’t helped. I’m using cactus juice if that has anything to do with it.
Thanks in advance.
2 replies so far
View bondogaposis's profile
4632 posts in 2283 days
#1 posted 05-17-2016 02:02 AM
Pictures? Stabilize first, cut thin later. Something isn’t right if the 1/4 sawn is cupping. I’d say too much heat on one side. What temp are you using?
-- Bondo Gaposis
2 posts in 672 days
#2 posted 05-17-2016 02:32 PM
200*. Yes, they are already cut. I was wondering if I should be stabilizing a block, then cutting.
