Special Grind Box Joint Blade
Forum topic by RandyinFlorida posted 05-16-2016 02:15 PM 1375 views 0 times favorited 10 replies Add to Favorites Watch
View RandyinFlorida's profile
RandyinFlorida
257 posts in 2270 days
05-16-2016 02:15 PM
Topic tags/keywords: box joints saw blades table saw incra i-box i_box flat ground raker tablesaw
The Incra I_Box User’s Manual suggests “You can cut delicate 1/8” box joints using standard 1/8” kerf table saw blades, but you’ll want to choose a blade that features a flat ground raker tooth or a special box joint grind like
those from Forrest and Ridge Carbide.”
These blades are pretty expensive; ranging from $89 for a 6” blade on up to $2-300. Anybody have an alternative? Of course my Big Box store has nothing. They all leave a rounded, high in the middle, bottom.
Yes, most men want a nice rounded bottom. But I need mine flat. lol
-- Randy in Crestview Florida, Wood Rocks!
10 replies so far
View Picklehead's profile
Picklehead
1050 posts in 2132 days
#1 posted 05-16-2016 04:57 PM
How about a 4 winged chipper from a dado set? I frequently use mine (Freud 4 wing) to cut flat-bottomed grooves without using the outside blades. For example, the grooves in the Quoridor board.
-- Quote from ebay tool listing: " Has nicks and dings wear and tear dust and dirt rust and pitting but in good working condition"
View bbasiaga's profile
bbasiaga
1240 posts in 2197 days
#2 posted 05-16-2016 05:28 PM
My brother just bought a two blade box joint set for I think $99 from Woodcraft. A Freud I think.
Brian
View BigYin's profile
BigYin
421 posts in 2619 days
#3 posted 05-16-2016 05:47 PM
Phone a saw sharpener and ask if they can recut the teeth of a blade to flat top instead of raked
-- ... Never Apologise For Being Right ...
bandit571
21775 posts in 2886 days
#4 posted 05-16-2016 06:10 PM
Backsaw and the right sized chisel….
View DirtyMike's profile
DirtyMike
637 posts in 1104 days
#5 posted 05-16-2016 06:10 PM
how about a flat top ground ripping blade?
View HorizontalMike's profile
HorizontalMike
7770 posts in 3116 days
#6 posted 05-16-2016 06:24 PM
- DirtyMike
BINGO! I was just thinking about my 24T Freud. IMO, the answer… 8-)
View Rentvent's profile
Rentvent
151 posts in 1051 days
#7 posted 05-16-2016 06:27 PM
Flat Tooth Grind saw blade
Be careful to get one that is truly FTG on all teeth – not a combination FTG blade.
HorizontalMike
#8 posted 06-10-2016 11:40 PM
Personally, I ended up with the Freud Box Cutter Blade:
http://www.rockler.com/freud-box-joint-cutter-set
Not ready for dovetail joints, but this is an easy alternative and actually just as strong in joining.
View Dan P's profile
Dan P
723 posts in 2094 days
#9 posted 06-12-2016 04:31 PM
Infinity makes a .125 kerf flat grind listed for 49.90 in the latest catalogue they sent. They also have 8” .156” kerf and .250” kerf flat grind.
I have the .156 and am very happy with it, as opposed to the Forrest 3/16”/3/8” box joint set which chipped a tooth and rusted badly
-- Daniel P
View xeddog's profile
xeddog
211 posts in 3210 days
#10 posted 06-13-2016 04:45 PM
I was at a woodworking show in Sacramento years ago, and Forrest had a booth there. One of their show specials was a WoodWorker II blade with a special grind for box joints, so I bought one. If anyone is interested, I think you can still order the WWII with special grind #1.
Wayne
