TABLE SAW *Molding Head* Kromedge Cutters
Forum topic by tchara posted 05-16-2016 01:00 PM 1380 views 0 times favorited 15 replies Add to Favorites Watch
View tchara's profile
tchara
33 posts in 825 days
05-16-2016 01:00 PM
Topic tags/keywords: jig question
When I bought my Craftsmen TS from a garage sale, it came with an assortment of blades in a wooden box. This thing was among them. Is it safe to use on a modern table saw. I guess its to create moldings and dados? https://s3.amazonaws.com/vs-lumberjocks.com/o79tcio.jpg!
15 replies so far
View knotscott's profile
knotscott
8099 posts in 3457 days
#1 posted 05-16-2016 01:17 PM
I used them successfully quite a while back, and they can do some things most router bits struggle with. Just make sure that all the threads are intact and tightened well. I’ll warn ya though….I recall the sound they make as being a little terrifying!
View ArtMann's profile
ArtMann
1008 posts in 898 days
#2 posted 05-16-2016 01:28 PM
I owned a set like that back in the 1980’s. I thought it worked rather well but, as knotscott said, it is kind of scary to use. I eventually became so nervous about it that I stopped using it and sold it.
View 01ntrain's profile
01ntrain
255 posts in 1152 days
#3 posted 05-16-2016 03:15 PM
I agree with the above….LOL. I used mine with the fluting cutters to make door trim in my house. Worked great, but I made sure that I had plenty of featherboards….and I also stepped my cuts as not to remove too much at one time. I’m not sure I would use the other ones….to me they seem a bit more dangerous.
tchara
#4 posted 05-16-2016 04:54 PM
They looked scary to me too, just sitting in the package. I’ll hold on to them. Maybe in a unique project I might throw caution to the wind, and try them out.
Thanks for the info
View hotbyte's profile
hotbyte
991 posts in 3057 days
#5 posted 05-16-2016 06:35 PM
Another vote for the sound being awful dang scary. Used mine in late ‘80s early ‘90s for cope & stick cabinet doors. I moved to a router based setup pretty quick after a few doors thinking my TS was going to take flight.
View Jim Finn's profile
Jim Finn
2663 posts in 3004 days
#6 posted 05-16-2016 06:38 PM
I have a set like that . Never have tried them. They were given to me. I see Harbor Freight sells a similar product.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
View muleskinner's profile
muleskinner
897 posts in 2518 days
#7 posted 05-16-2016 06:39 PM
I picked up a set at a garage sale a couple years ago. I think I paid about 10 bucks. Haven’t had the opportunity or the nerve to use them yet.
-- Visualize whirled peas
View MrUnix's profile
MrUnix
6845 posts in 2281 days
#8 posted 05-16-2016 06:44 PM
Depends on the saw… the arbor needs to be fairly robust to handle the forces involved. I’m guessing that since it came with the saw you bought, it probably is fine. For years, the user manuals for most of the larger Delta saws, particularly the Unisaw, advertised their version of a moulding head cutter (Cat #24-813) and lots of various shaped knives. I have one of those and while it takes some getting used to, does work as advertised – although in many cases, a router table is a better method to accomplish most profiles.
View Bill White's profile
Bill White
5007 posts in 4042 days
#9 posted 05-16-2016 08:19 PM
Might sound like an F-86, but they do work well if ya have the moxie on the saw.
I’ve used mine on a radial saw as well as a TS. As was said, be sure the gib screws are tight and the blades are sharp.
They/it work(s).
Bill
-- bill@magraphics.us
View jimintx's profile
jimintx
806 posts in 1666 days
#10 posted 05-16-2016 08:26 PM
I bought one a few decades ago, and used it a few times, not much. I still have it, and there is no way in the world I would try to use it ever again. I am really much safer with that thing in its plastic case, on a shelf, and in a cupboard.
-- Jim, Houston, TX
View WhyMe's profile
WhyMe
1034 posts in 1643 days
#11 posted 05-16-2016 09:40 PM
Nice to know I’m not the only one who found that molding head to be scary to use. I used mine on a radial arm saw back in the 80’s and it just made me nervous. Haven’t used it since then.
View Dan Krager's profile
Dan Krager
4105 posts in 2316 days
#12 posted 05-16-2016 09:55 PM
To enhance the scary sound and at the same time reduce some of the hazard, a ZC insert should be made for each cutter set. Ease into the cut with shallow (!/8”) cuts to sneak up on the last pass which will be very very clean at 1/16” removal. Proper hold downs (a board clamped to the fence and table work well) and proper feeding (not too fast not to slow…work the motor but don’t be racing) will result in a great variety of beautiful, efficient cuts. Along with the good advice above, observe all the safety rules of using a shaper or jointer. DO NOT USE ON A RADIAL ARM SAW!
Overall, this is no more dangerous than a jointer, shaper, dado head or just a powerful table saw. Use it with the appropriate respect and it will serve you well as long as my four have…some 50 years.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com The witchcraft of woodworking.
WhyMe
#13 posted 05-16-2016 10:16 PM
DanK
- Dan Krager
You say that, but the Craftsman instructions for the molding cutter shows how it’s to be used on a radial arm saw. The motor head is to be turned vertical with the cutters protruding through the fence. But with that said, I agree with you.
View oldnovice's profile
oldnovice
7017 posts in 3449 days
#14 posted 05-16-2016 10:40 PM
I had the exact same cutters!
I bought a tongue and groove cutter for it and used it once.
It was scary so I added guards to guide the material, at the same time keep the cutters contained, and make sure my fingers couldn’t even get close to the cutters.
Don’t know what I did with it but good riddance, I’ll use my router instead!
Dan Krager
#15 posted 05-16-2016 10:45 PM
Ya, that vertical setup works the best, WhyMe and the first thing I wanted to do with my new purchase of Craftsman radial saw was put molding on the edge of a board that was too wide to stand on edge. I completed it safely, but it burned a whole new respect into my memory for the shaky setup involved in cutting it flatways.
DanK
