over dry butternut
« back to Coffee Lounge forum
Forum topic by hornhunter posted 04-05-2010 08:35 PM 1944 views 0 times favorited 8 replies Add to Favorites Watch
View hornhunter's profile
21 posts in 2985 days
04-05-2010 08:35 PM
Topic tags/keywords: butternut question
My father had some butternut boards in his garage attic for 30 tears or so. I got one down a few weeks ago and planed it and had some bad tear out. The wood is too dry. Is there a remedy for this other than lots of sanding?
-- Dean, Kinderhook, New York
8 replies so far
View barlow's profile
129 posts in 3672 days
#1 posted 04-07-2010 04:44 AM
Butternut usually tears when the knives are dull, and/or if the stock isn’t dry kilned. As you know butternut is a very soft wood which is not prone to brittleness at lower moisture contents as with your dense hardwoods such as ash, hickory, maples or oaks. And sometimes no matter what you do it may raise the grain just because.
-- barlow
#2 posted 04-07-2010 02:33 PM
thanks for the info. I have not worked with it before. I was expecting it to be similar to walnut.
View richgreer's profile
4541 posts in 3006 days
#3 posted 04-07-2010 05:18 PM
Butternut has been referred to by some as “white walnut”. In actual fact, it is not related to walnut at all and is quite different (much lighter).
View Jimthecarver's profile
1124 posts in 3717 days
#4 posted 04-08-2010 03:43 PM
I do know butternut makes for some very good carving wood.
View SteviePete's profile
226 posts in 3235 days
#5 posted 05-20-2010 07:23 PM
Butternut, Juglans cinerea, is in the walnut family (Juglans sp). It is the most beautiful dark, heavily grained wood, soft, superburb for carving. Defects include insect damage, branches and reaction wood and loss of sap wood on the dead portions of the tree.
I suggest: Start with a tuned plane—any gross amateur can plane full lenth, full width tight curls. Make them thinner and thinner. Whittle a small ball in cage—-2×2x4. Carve only with the grain. Use an alcohol spray to soften up the hard parts (evaporates w/o raising the grain). Use slicing strokes. If you break off a piece glue it back on with superglue.
Look at the work of Norsk Woodworks (Phillip Odden and Else Bigton), Fred Cogelow, Roger Strautman (LJ)—- all expert, all good teachers with an impressive body of work in butternut. Butternut is not long for this world…it is susceptable to canker. Little to none of the current production comes from live, non-infected trees. Trying to keep as many alive as long as we can. Folks on the Walnut Council and at the Forest Products Lab in Madison, Wisconsin are good resources for more information on butternut. In Wisconsin we still have some butternut on the hoof. I’ll be processing some ratty logs soon. PM me if you have a special piece in mind. Go Badgers. Visit ‘sconie, good butternut, good beer, good babes!
What have you done with the subject of this post? spj
-- Steve, 'Sconie Great White North
117029 posts in 3509 days
#6 posted 05-27-2010 06:19 AM
Now I know more about butternut thanks guys
-- wood crafting & classes
View Jim Jakosh's profile
Jim Jakosh
20168 posts in 3037 days
#7 posted 05-27-2010 06:38 AM
Okay, this may be a dumb questions but if a walnut tree actually has walnuts on it, does a butternut tree actually have butternuts on it??
I have never had any to work with.
#8 posted 05-27-2010 03:41 PM
Only the boy trees. (not true) Look here:
