Router Inlay Equipment Question
Forum topic by weekender posted 12-09-2007 07:34 AM 1022 views 0 times favorited 2 replies Add to Favorites Watch
View weekender's profile
weekender
7 posts in 3708 days
12-09-2007 07:34 AM
Topic tags/keywords: question
I am trying to do my first inlay project and am having troubles. I have a Bosch B1450 plunge router and am confused about what I need to buy for it to route inlays. The inlay template bushing sets online for Bosch seem to reference other models. Does anybody know if they will work for mine? Also, after having bought a universal template set at HD it now appears I got the wrong thing as it doesn’t have threaded guides which it appears I need for the inlay sets. Am I right? Help would be appreciated!!
-- Steve
2 replies so far
View Max's profile
Max
56000 posts in 4146 days
#1 posted 12-09-2007 07:38 AM
weekender,
Here is a link to the inlay set that I have for my router. http://www.woodcraft.com/family.aspx?FamilyID=1391&refcode=05INFROO
If your router will accept Porter Cable sets this should work.
View Sawdust2's profile
Sawdust2
1467 posts in 3961 days
#2 posted 12-09-2007 11:21 AM
Without looking up a B1560 look at your router base and see if it has a lever that rotates about 30 degrees over a base with about 4-5 teeth.
Of so, Bosch has a set of bushingss that fit in.
Otherwise buy an insert that allows you to use the other bushings.
See if this doesn’t help
http://www.highlandwoodworking.com/index.asp?PageAction=VIEWCATS&Category=310&Page=2
