Need a flange for an older Delta miter saw
Forum topic by gdiddy13 posted 05-14-2016 04:28 PM 603 views 0 times favorited 2 replies Add to Favorites Watch
View gdiddy13's profile
gdiddy13
59 posts in 979 days
05-14-2016 04:28 PM
Hi guys,
I’ve been floating around here for a bit.
I been putting together what was my grandfather’s older(ish) Delta miter saw. I thought I had it all together, then realized I’m missing the flange for it, and this part is obsolete.
Anyone have ideas where I might be able to locate this part, or is anyone parting one out?
10” Delta miter saw- model 36-070
Thanks guys and gals!
2 replies so far
View MrUnix's profile
MrUnix
7106 posts in 2435 days
#1 posted 05-14-2016 08:17 PM
Are you talking about the flange washer (sometimes referred to as the blade washer)? If so, those are fairly standard across machines and manufacturers – so while you might not find the exact OEM branded washer, you should be able to find one similar enough to work. The OEM part for your saw was used on dozens of other Delta and Porter Cable saws, so I’d start there.
gdiddy13
#2 posted 05-14-2016 08:39 PM
That’s great info, thanks!
