Rikon slow speed grinder not as slow as I'd like
Forum topic by ColonelTravis posted 05-13-2016 05:42 PM 733 views 0 times favorited 9 replies Add to Favorites Watch
View ColonelTravis's profile
1748 posts in 1830 days
05-13-2016 05:42 PM
Topic tags/keywords: rikon slow speed grinder
Got a cup of water nearby every time I grind something, and it never stays on the wheel for more than a couple seconds. I know the wheels run slower than my other normal grinder but sometimes I’ve watched videos of people on slow speed grinders (not Rikon) and they grind, grind, grind and never blue the steel, never touch water. That’s simply not the case with mine. Are there slower brands?
I’ve looked into those expensive diamond wheels, do they help (as far as low heat)?
It’s this one, which is fairly popular
9 replies so far
View TheFridge's profile
9112 posts in 1422 days
#1 posted 05-13-2016 05:58 PM
I find dressing my wheels regularly helps.
View Woodknack's profile
11319 posts in 2316 days
#2 posted 05-13-2016 06:22 PM
Yeah I don’t know why they run them so fast. I would prefer my slow speed grinder to be a good bit slower too.
-- Rick M,
View jdh122's profile
992 posts in 2754 days
#3 posted 05-13-2016 07:42 PM
For slower, people move to the Tormek and clones.
Like the Fridge, I find that frequent dressing is key to grinding without losing temper (I use a regular high speed grinder).
Not sure, but I think the diamond wheels are mostly for HSS, not regular tool steel. Great for turners, but not so much for planes and chisels.
-- Jeremy, in the Acadian forests
View jimintx's profile
708 posts in 1521 days
#4 posted 05-13-2016 07:44 PM
I usually avoid the heat build up with that exact grinder, by making sure to apply very little pressure. Overall, I lie that grinder.
-- Jim, Houston, TX
#5 posted 05-13-2016 07:55 PM
Thanks Fridge, I’ve got that Wolverine dresser, I’ll try using it more and see if it helps.
Now that I think of it, when I was talking to a guy at a wood shop about the diamond wheel, he was a turner. I never thought about an issue tool steel. Not like I’m gonna buy one soon, they are real pricey.
View waho6o9's profile
8135 posts in 2513 days
#6 posted 05-13-2016 08:07 PM
#7 posted 05-14-2016 03:13 AM
I got mine off of Ebay and it works well for me.
- waho6o9
Same as the Rikon, different paint. Mine too, different brand but identical to the Rikon.
-- Rick M,
View Andre's profile
1723 posts in 1742 days
#8 posted 05-14-2016 05:47 AM
The Cool Grinding Wheels from Lee Valley help with heat build up but do need constant dressing.
I use a hand powered grinding wheel with a Cool Grinding wheel for all my final finish and touch ups, makes a nice hollow grind on chisels and plane irons.
View rwe2156's profile
2846 posts in 1417 days
#9 posted 05-14-2016 11:24 AM
A lot depends on the grinding wheel (maybe more than speed). Fine = heat.
When hollow grinding chisels I don’t even touch the fine stone anymore.
