band saw tires - crown them ?
Forum topic by dbw posted 05-13-2016 11:54 AM 656 views 0 times favorited 2 replies Add to Favorites Watch
View dbw's profile
dbw
187 posts in 1511 days
05-13-2016 11:54 AM
Topic tags/keywords: band saw tires crowning
I bought a used BS on CL with the original rubber tires. They are in decent shape. The bottom tire has a bit of a ridge but I think I can let it ride (pun intended). I’ve cleaned them and my question is should I crown them ? If so how much?
-- measure 3 times, cut once
2 replies so far
View distrbd's profile
distrbd
2252 posts in 2321 days
#1 posted 05-13-2016 12:42 PM
I would first put a blade on and see how it tracks on the wheels, if it cuts nice and straight ,then leave it alone for now but if the blade does not track properly or it’s not stable on the upper wheel/does not stay centered, then look at the possible causes.
I have owned a couple of bandsaws that their wheels were flat,(i.e.Rockwell model# 28115, Ryobi ), a picture of your saw would help a lot. it is not highly unusual for bandsaw wheels not to have a crown, or maybe the wheels are casted with a crown in them which means you don’t necessarily need to crown the tires.
-- Ken from Ontario, Canada
View dbw's profile
dbw
#2 posted 05-14-2016 10:00 PM
It cuts very well. I will leave the tires alone. Thanks.
