Used G0513
Forum topic by ChrisBarrett posted 05-13-2016 03:23 AM 821 views 0 times favorited 6 replies Add to Favorites Watch
View ChrisBarrett's profile
ChrisBarrett
99 posts in 1081 days
05-13-2016 03:23 AM
Apparently from 2008, $600. Any thoughts as to buying these used? I’ll be using primarily for resawing hardwoods.
View gfadvm's profile
gfadvm
14940 posts in 2714 days
#1 posted 05-14-2016 12:06 AM
That’s more than I would offer UNLESS it is the Extreme Series with the cast iron trunions, wheels, and the resaw fence.
ChrisBarrett
#2 posted 05-14-2016 03:43 AM
I did end up getting it for $600 with 3 extra blades. Honestly it’s extremely difficult to find used bandsaws around here, they are all the 12” craftsman variety, which I already have. It appears to be in good shape and only needs a new throat plate. It’s the base model, with the aluminum wheels and steel trunions.
View bonesbr549's profile
bonesbr549
1557 posts in 3091 days
#3 posted 05-14-2016 11:24 AM
Thats not a bad price IMO. I’ve had mine about that long, and its been a great saw. I use mine for resaw only as I have a 1934 Delta 14” for everything else. I highly recommend the laguna carbide tipped blade. It ain’t cheap but it makes a butter smooth cut and will last forever. I’m going to send you PM on how to get a discount on that blade. Timberwolf blades for general cutting. Good luck.
ChrisBarrett
#4 posted 05-14-2016 01:16 PM
Do they make the laguna resaw king in the right length for the g0513? I think it’s 131.5”...
ChrisBarrett
#5 posted 05-14-2016 04:27 PM
To answer my own question, they say the 132” blade should fit well enough. I just worry that there would be enough tension for a 3/4” blade at 132”.
bonesbr549
#6 posted 05-14-2016 05:43 PM
.5” either way will not make a diff in length. You buy the resawking by the inch anyway. I think if memory serves me right, I wen +.5 on recommendation from Laguna. Its been runnin fine since then.
