Which glue? Wood to brass
Forum topic by Lisa Chan posted 04-03-2010 11:58 PM 9374 views 0 times favorited 9 replies Add to Favorites Watch
View Lisa Chan's profile
Lisa Chan
147 posts in 3087 days
04-03-2010 11:58 PM
Topic tags/keywords: question
I have a brass spindle that has a wooden whorl (the black you see is just cover tubing… the shaft is pure brass)
It was secured with some kind of rubbry silicon glue that didn’t stay put… and eventually detriorated with friction so now the whorl slides down the shaft (this thing works like a top and you spin it around with the weight of yarn on the shaft and resting on the whorl).
What kind of glue do I want to use to fix this thing? And how might I apply it?
-- Lisa Chan, custom cafts and yarn accessories,
9 replies so far
View Roper's profile
1389 posts in 3649 days
#1 posted 04-04-2010 12:02 AM
pen turners C A glue. wood craft or rockler will have it.
-- Roper - Master of sawdust-
View Glen Peterson's profile
Glen Peterson
556 posts in 2993 days
#2 posted 04-04-2010 12:14 AM
CA is a great choice, Gorilla Glue will work too.
-- Glen
View cstrang's profile
1832 posts in 3105 days
#3 posted 04-04-2010 12:27 AM
I always use someone here suggested it a while ago… can’t quite remember who brought it up though.
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
Lisa Chan
#4 posted 04-04-2010 12:29 AM
Which is interesting… because Gorilla Glue and CA glues are not what it recommended. Confusing!
View interpim's profile
1170 posts in 3395 days
#5 posted 04-04-2010 12:48 AM
the brass tubes in pens are sometimes affixed with CA, and with the little amount of force applied on a pen, it will hold up. I have had a few problems with CA and the brass tubes holding well enough.
My recommendation is to use a 2 part epoxy… I have used that in the past on brass/wood combos and haven’t had it fail yet. Just be sure to rough up the brass a bit to get rid of any tarnish and give a better grip to the glue you use.
-- San Diego, CA
View hObOmOnk's profile
1381 posts in 4064 days
#6 posted 04-04-2010 01:21 AM
The Gorilla Glue Company has several options for this type of gluing.
-- 温故知新
View Tony_S's profile
844 posts in 3019 days
#7 posted 04-04-2010 01:52 AM
JB Weld or Weldbond.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View Dez's profile
1166 posts in 4014 days
#8 posted 04-04-2010 09:34 AM
I vote for CA (Superglue). Thin bodied will flow in and bond to cover more surface area.
-- Folly ever comes cloaked in opportunity!
View richgreer's profile
4541 posts in 3011 days
#9 posted 04-04-2010 03:04 PM
Lots of opinions here and mine will be one more. I’d use epoxy. It’s a pain to work with but i’ve always had good luck with it in wood to metal.
